Outlet Box Five Hole 1/2 In. By ACE Hardware - Electrical - DIY Chatroom Home Improvement Forum
Old 05-30-2008, 05:52 PM   #1
Outlet Box Five Hole 1/2 in. by ACE hardware
Hi, I am having trouble installing my light fixture in my bathroom. I recently had the hollywood vanity lights and took them down only to find no outlet box but just the wires sticking out. I went to ace hardware to buy a outlet box to help mount my new light fixture, but the box did not come with screws. So now I am stuck b/c I can't find screws to fit into the five holes and might just call the electrician to hang this up for me. Please help!
handywoman99 is offline   Reply With Quote
Old 05-30-2008, 06:20 PM   #2
joed's Avatar
Rewards Points: 13,288
Electric box holes are normally 6-32 machine screws.
Old 05-30-2008, 08:52 PM   #3
Round junction boxes typically used for light fixtures are 8/32 machine screws and retangular boxes used for receptacles are 6/32 machine screws.
adave is offline   Reply With Quote
Old 05-30-2008, 09:55 PM   #4
Power Gen/RS Engineer
Rewards Points: 566
5 holes? I'm not sure I follow...
Is this a remodel box, i.e. a single-gang with 1/2" knockouts? Are the screws that you say are missing for attaching the fixture?
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 05-30-2008, 10:11 PM   #5
Actually can someone tell me where I can buy a pancake pan and hanger to attach to the studs to?
http://www.flickr.com/photos/thevinc...57605341737718
Old 05-30-2008, 10:53 PM   #6
Registered User
Termite's Avatar
You don't need a pancake box with that type of hanger for a wall mounted fixture. If the fixture is located right in front of a stud, a pancake box can be screwed right into the stud. If not, you're better off with a plastic cut-in box. You cut a hole for the box to fit in and screw in two screws, which will cause plastic flaps to extend behind the wallboard and secure the box in place. Very, very easy.
If you do decide that you want to use a metal box, you MUST make sure that the box itself is correctly grounded with a green screw or clip. There is a threaded hole in the back of all metal boxes to receive the green screw, which does not come with the box.
Old 05-31-2008, 10:13 AM   #7
Electrical Contractor
jbfan's Avatar
Rewards Points: 530
As I said in my other post, that box and strap is home made.
jbfan is online now   Reply With Quote
Old 05-31-2008, 10:44 AM   #8
Okay, but where do I buy the plastic box from? Do you have a link of what it looks like?
Old 05-31-2008, 10:59 AM   #9
Rewards Points: 204
I may be wrong, but if I remember correctly you don't need a box. Someone can clarify, but maybe you can just mount the new fixture like the old one.
Proper way to repair oversized outlet hole in drywall Plasmech Painting 16 06-24-2010 11:09 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 10:28 AM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
