Outlet Box: Extension Possible? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-31-2007, 04:55 PM   #1
outlet box: extension possible?
I have decided to install beadboard planks, 9/16 in thick, over the drywall in my bathroom. My problem is the outlet boxes are placed, of course, so that the receptacles and switches are flush with the drywall.
I used the blue plastic type outlet boxes when I first installed them.
Do I have to pull the boxes and reseat them 9/16" out, or is there a code-friendly way to leave them in place and get the receptacles and switches flush with the beadboard?
Thanks.
SJ
sloppyJoe is offline   Reply With Quote
Old 08-31-2007, 05:24 PM   #2
Box extenders also called plaster rings are available even at the big box stores. Happy hunting! Eventually the electric guy will get there to show you where they are at.
this is the " right way" to do it.
Big Bob is offline   Reply With Quote
Old 09-01-2007, 12:47 AM   #3
Thanks for the reply
Thank you.
Old 09-01-2007, 07:07 AM   #4
Licensed Pro
Box extenders by the same manufacturer as the blue boxes are available and should be used. They are NOT the same thing as a plaster ring.
Old 09-01-2007, 09:08 AM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,872
I use Arlington BE-1's for this purpose.
Old 09-02-2007, 12:24 AM   #6
Thanks!
Thanks for your help. I begin work tomorrow.
Old 09-02-2007, 09:09 AM   #7
Master Electrician
JohnJ0906's Avatar
So do I. Don't forget longer 6/32 screws. The ones that come with the receptacles never seem to be long enough.
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Electrical outlet hook up. helpless handyman Electrical 4 07-30-2007 09:18 PM
Bathroom outlet - distance from tub?? plbsplbs Electrical 11 07-09-2007 09:22 PM
20a Outlet Vs. 15a Outlet bobo Electrical 3 05-29-2006 11:55 PM
Adding garage outlet Shane Electrical 1 02-23-2006 05:43 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 09:45 AM
