Outlet Box - Electrical - DIY Chatroom Home Improvement Forum
Old 06-02-2011, 04:21 PM   #1
Outlet box
I want to install a couple of plastic outlet boxes in exsisting drywalled walls, how do I fasten them?
florpro is offline   Reply With Quote
Old 06-02-2011, 04:25 PM   #2
Licensed electrician
Rewards Points: 1,746
Plastic old work boxes has wings that flip out behind the drywall. There is a nicer style that secures to the studs. Google smartbox.
Old 06-02-2011, 04:36 PM   #3
Here is a picture of the box. Would you also put screws in the holes through the drywall?
Old 06-02-2011, 04:38 PM   #4
Screws do not hold in drywall. The flip out wings should be enough.
Old 06-02-2011, 04:41 PM   #5
So if my hole is a little bigger than the box or tilted then the box will be too?
Old 06-02-2011, 04:46 PM   #6
The hole can be straightened, but the tabs must has something to grab so it doesn't fall into the wall.
Old 06-02-2011, 11:35 PM   #7
Rewards Points: 512
The flange keeps the box from falling into the wall, the wings keep it from falling out
Switched Outlet Issue mjm Electrical 13 06-14-2015 07:56 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 08:38 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
