Outlet Behind Door ? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-12-2012, 09:54 AM   #1
Rewards Points: 216
outlet behind door ?
i am rewiring a bedroom. the wall with the window is 10'ish. on the right side of the window = between window and corner, will be an outlet.
the left side of the window. there is a closet door, on the left wall, that opens to be flush with the window wall. so no furniture can be put there. should i put an outlet there anyway ?
Fix'n it is offline   Reply With Quote
Old 08-12-2012, 09:57 AM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
If the wall space is 24" or larger. It is required.
Old 08-12-2012, 09:57 AM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
By code you need a receptacle within 6' from that door.
Old 08-12-2012, 09:59 AM   #4
E2 Electrician
What he said. ^ hate reading on my phone.
Old 08-12-2012, 10:34 AM   #5
Rewards Points: 216
ok, i will put one there. be not much could be plugged in there. except a vacuum cleaner or something. but no matter, i will put one there. but why would an outlet be required by a closet door ?
thanx
Old 08-12-2012, 10:36 AM   #6
k_buz's Avatar
You need an outlet on any wallspace greater than 24". You need a receptacle 6' from any break in the wall and 12' after that. Its code. As to why? It takes the guessing out of it.
Old 08-12-2012, 10:37 AM   #7
E2 Electrician
thanx
It's actually the perfect spot for a general purpose receptacle, you know it won't get buried by furniture.
Old 08-12-2012, 10:38 AM   #8
Rewards Points: 216
ok, thanx. consider it done.
interesting patio door problems....please help. diybrad Building & Construction 6 11-21-2011 12:52 AM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 04:01 AM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 09:43 AM
