Outlet Before GFCI String - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-06-2014, 12:52 PM   #16
Semi-Pro Electro-Geek
Rewards Points: 2,860
Originally Posted by rdarlin2 View Post
Rather...
I did listen to Jim. I do not plan to use the GFCI circuit/power for the outlet.
The power circuit/line I plan to use currently powers the light switch in the bath, as well as outlets in other rooms. The bath light is currently the first use of that line; and I plan to add the outlet in front of the bath light switch.
Are we talking about the same thing? or am I confusing the issue?
Rich
I can't tell for sure what you have going on. Your earlier posts, and the title of this thread, definitely make it sound like you wanted to put the new receptacle on the same circuit as the bathroom receptacles. Now is sounds like you have two circuits feeding the bathrooms, with the lights on one circuit and the receptacles on another circuit. If that's the case, then you can put the new receptacle on the breaker that feeds the lights. But obviously you can't put it on the same breaker as the bathroom receptacles, because that's the problem I and others have been talking about.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
The Following 2 Users Say Thank You to mpoulton For This Useful Post:
ratherbefishing (01-07-2014), rdarlin2 (01-07-2014)
Tags
gfci switch/outlet
Bathroom GFCI Outlet trouble RyG1357 Electrical 3 08-20-2011 04:40 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
Porch outlet, and livingroom on bathroom GFCI circuit? Is that uncommon? 211 Electrical 5 01-06-2011 03:13 PM
GFCI outlet failed in a rain storm, now has no power! Kaybee33 Electrical 5 12-28-2010 06:38 PM
Replacing outlet to new GFCI - Wall switch Protonix Electrical 13 04-09-2009 09:36 AM
