Outlet Before GFCI String - Electrical - DIY Chatroom Home Improvement Forum
Old 12-31-2013, 04:06 PM   #1
Rewards Points: 20
Outlet before GFCI string
I have a dedicated power line running from the circuit panel to a 1/2 bath on the first floor (with a GFCI outlet), to two more GFCI outlets in the 2 upstairs baths.
Can I insert a non-GFCI outlet in this string, before the first GFCI outlet, and have it always hot? and not affected by a GFCI outlet closing the circuit further along in the string?
I would think so - but I thought I'd check.
Next, how would I connect the hot line from the circuit panel to both the always hot outlet AND the first GFCI outlet... within the first GFCI box?
I think I should be able to use wire nuts to join the hot line to the new wire for the new outlet, adding pigtail wires at each wire nut... and use these pigtail wires to connect to the GFCI hot, neutral, ground screws.
Thanks,
Rich
Rich
rdarlin2 is offline   Reply With Quote
Old 12-31-2013, 04:10 PM   #2
Master Electrician
Rewards Points: 3,680
No. As described this circuit should only serve BR receps. ALL bathroom receps must be GFCI protected.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
mpoulton (12-31-2013)
Old 12-31-2013, 04:47 PM   #3
Rewards Points: 20
Edit : there is no GFI Breaker in the breaker panel.
Old 12-31-2013, 06:46 PM   #4
Licensed electrician
Rewards Points: 1,028
You cannot have non-GFI receptacles in the bathroom.
Old 12-31-2013, 06:56 PM   #5
Semi-Pro Electro-Geek
Rewards Points: 2,858
...and you cannot have non-bathroom receptacles on the bathroom circuit.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
The Following 2 Users Say Thank You to mpoulton For This Useful Post:
brric (12-31-2013), Jim Port (12-31-2013)
Old 01-02-2014, 10:50 AM   #6
Rewards Points: 20
OK. Thanks for answering the question.
I'll use the light switch then, to power the outlet (which is going to be in an adjoining room).
Rich
Old 01-02-2014, 01:14 PM   #7
Not all switches have a neutral in the box. A switch loop is only hot conductors.
Old 01-02-2014, 04:42 PM   #8
Rewards Points: 948
Why do you want to do this? There might be a work around.
You can take the power off before the GFCI outlet to your new GFCI outlet; so that whatever happens on the first one doesn't affect the second one.
Toller is offline   Reply With Quote
Old 01-02-2014, 07:52 PM   #9
That doesn't fix any of the problems. Of course it can be wired that way, but it's not possible for that to be legal, for the reasons stated already: GFCI's are required in bathrooms, and non-bathroom receptacles are not allowed on the bathroom circuit. So this new receptacle is either A: in a bathroom, and therefore needs GFCI protection or B: not in a bathroom, in which case it's not allowed on this circuit.
The Following User Says Thank You to mpoulton For This Useful Post:
Jim Port (01-02-2014)
Old 01-03-2014, 05:56 PM   #10
Rewards Points: 20
For clarification, I intended to put the outlet facing into another room, powered by the power line into the light switch in the bathroom. I get that I should not use the GFI line - use that for GFI outlets only... (tks Toller/Mpoulton).
Jim, I don't want to 'loop' the outlet (as I understand it - that means the light switch would power off both the light and the outlet... putting the outlet before the switch, instead of the switch at the beginning of the circuit.)
I now have three lines leading into and out of the light switch box.
1- power from the breaker panel in
2- power from the light switch box that goes further to power other outlets etc.
3- power from the light switch box to the light.
I want to add one other line coming out of the light switch box that powers the new outlet. (again outside of the circuit that powers the light)
I think I should connect the black, white and ground of all 4 lines together, then pigtail off the lines to power the light switch.
Does that make sense?
Rich
Old 01-03-2014, 06:07 PM   #11
You do not have a switch loop. In a switch loop there is the hot white and the switched black hot.
Old 01-05-2014, 02:25 AM   #12
If it's on the same circuit as the bathroom receptacles, it's a code violation.
Old 01-05-2014, 01:47 PM   #13
Rewards Points: 20
Jim - it isn't a switch loop, I understand.
I've got a single pole light switch. The outlet won't be in line with the light - only the power to the light will be affected by the light switch. I intend to connect the new outlet power line from the incoming power line, before the switch circuit.
mpoulton - the outlet will not be on the same circuit as the bathroom GFI outlet
Old 01-05-2014, 10:13 PM   #14
In a little over my head
Rewards Points: 706
rdarlin2,
listen to mpoulton. although your new outlet will not be protected by the GFCI, it is (proposed to be) still on the same fused circuit and in another (non-bath)room. That is not allowed by code.
ratherbefishing is offline   Reply With Quote
Old 01-06-2014, 12:13 PM   #15
Rewards Points: 20
Rather...
I did listen to Jim. I do not plan to use the GFCI circuit/power for the outlet.
The power circuit/line I plan to use currently powers the light switch in the bath, as well as outlets in other rooms. The bath light is currently the first use of that line; and I plan to add the outlet in front of the bath light switch.
Are we talking about the same thing? or am I confusing the issue?
Rich
Tags
gfci switch/outlet
Bathroom GFCI Outlet trouble RyG1357 Electrical 3 08-20-2011 04:40 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
Porch outlet, and livingroom on bathroom GFCI circuit? Is that uncommon? 211 Electrical 5 01-06-2011 03:13 PM
GFCI outlet failed in a rain storm, now has no power! Kaybee33 Electrical 5 12-28-2010 06:38 PM
Replacing outlet to new GFCI - Wall switch Protonix Electrical 13 04-09-2009 09:36 AM
