Old 08-01-2007, 09:48 AM   #1
outlet in bathroom cabinet OK?
I would like to install a GFCI outlet on the side of my bathroom vanity cabinet. Is this permitted by NEC? Any extra rules relating to running the wire? Thanks
matty is offline   Reply With Quote
Old 08-01-2007, 09:44 PM   #2
What would it be used for?
redline is offline   Reply With Quote
Old 08-01-2007, 09:49 PM   #3
Master Electrician
JohnJ0906's Avatar
Are you planning on installing the GFCI on the cabinet itself, or beside it?
I don't know of anything in the NEC prohibiting this.
How do you plan on running the wire?
Any chance of a picture?
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Old 08-01-2007, 10:43 PM   #4
remodeling pro
There is nothing against this, but any exposed wires in the cabinet must be encased in conduit, either flexible or ridgid. We install outlets in the sides of cabinets all the time for kitchen islands.
troubleseeker is offline   Reply With Quote
Old 08-01-2007, 11:51 PM   #5
Thanks for your comments. It will be used for a hair dryer, mostly. There is a tall linen cabinet next to the counter. I will run the wire up from the basement (using conduit ). The outlet will be recessed in the cabinet itself, just above the counter level. I think it's a go. Any other thoughts?
Old 08-02-2007, 10:56 PM   #6
remodeling pro
Just installed two exactly like that in a pair of tall linen cabinets flanking the vanity bowls. For a really neat job, or just to be anally retentive like me, do what I did. First, locate the outlets within a couple of inches of the rear of the cabinet. I then took a couple of pieces of 1 by material and made a little 3 piece box, two sides and a top, to enclose the outlet and wire from view. A couple of beads of adhesive caulk will hold them in place, yet allow for prying them loose should it ever be necessary. Even though you will be the only one to probably see them inside the cab, it will make you feel good every time you open the cabinet and do not see an ugly electrical box and conduit.
Bathroom outlet - distance from tub?? plbsplbs Electrical 11 07-09-2007 09:22 PM
GFCI Outlet installation in bathroom... budde97 Electrical 4 02-11-2007 01:22 AM
Outlet in bathroom for lights.... TerryL Electrical 5 10-28-2006 09:46 PM
Bathroom Outlets - How far above finished cabinet height? MikeinBurien Electrical 4 12-10-2005 12:11 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 09:45 AM
