Outlet Amps? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-27-2013, 03:47 PM   #1
Question
Outlet amps?
What are some possible conclusions when you plug something into an outlet and it runs something but at lower pace/speed. i.e. plug a mixer in it runs but slow. I've been told it isn't getting the needed amperage, I check volts and the read 120.
If they tied this into a higher voltage line, say for a electric stove, could that do it? Don't know if that's possible, I haven't tried to flip breakers yet either to see where they are tied into.
number1noid is offline   Reply With Quote
Old 12-27-2013, 03:52 PM   #2
Licensed electrician
Rewards Points: 1,020
A poor or loose connection can read correct voltage but it will drop under load.
Old 12-27-2013, 03:58 PM   #3
dmclean701's Avatar
Rewards Points: 152
If the outlet is truly providing 120 volts then the appliance will draw the amps it is designed for. Try plugging into another outlet, if the appliance still runs slow, it is a fault in the appliance. A high resistance would cause this, like a bad switch.
Sent from my iPad using DIY Forum
dmclean701 is offline   Reply With Quote
Old 12-27-2013, 04:05 PM   #4
I have two outlets within 3 feet of each other, both are doing this. I know the appliances are fine I plug them into a different outlet on other side of the room and function fine.
Old 12-27-2013, 04:20 PM   #5
Rewards Points: 12,830
Then both the outlets are on the same circuit.
The fault could be any place from the buss the breakers plugged into, the connection on the breaker, any place on that circuit with a loose connection, back stabbed outlets ECT.
All it takes is one loose connection and anything beyond that point will be effected.
Speedy Petey (12-27-2013)
Old 12-27-2013, 04:22 PM   #6
K thanks I will look into it.
Old 12-28-2013, 02:15 PM   #7
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Check the speed selection on the mixer....
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 05:14 PM
Outlet not working, reading "open ground" syren Electrical 3 04-19-2010 05:20 PM
Generator as sole power source NGuy Electrical 29 12-20-2008 01:29 AM
Max amps allowed - electrician advice needed Des Electrical 27 06-05-2008 11:31 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
