Outlet - 220' Underground Run - MWBC - Electrical - DIY Chatroom Home Improvement Forum
Old 10-15-2012, 03:51 PM   #1
Rewards Points: 502
Outlet - 220' underground Run - MWBC
I have a 220' conduit run from the house to the end of the driveway that I want to finally pull electric thru for Christmas lights, etc.
The total distance run from there to the panel, will be in the neighbor hood of 280'.
My initial plan was to pull a single circuit with #12, but now I am considering making it two circuits.
So long as I put each circuit on a separate phase in the panel, I can share the neutral, correct?
Someday we might put a gate out there, so I might as well run the second circuit now.
So I can pull 4 #12 wires (2 blacks, 1 white and 1 green)?
Voltage drop will be acceptable for this purpose, especially since bumping up to #10 increases the cost by $40 per run when considering that I'll purchase 4 - 500' spools. (A $200 difference)
I did a voltage drop calculation and for #12 at 15 amp load for 280' gives me a voltage of 106. In the past, we have used #14 cords to handle probably 10 strands of lights and I think that only pulled 5 amps.
I dont care if the Christmas lights get 106v instead of 120, especially considering LED strings pull less.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 10-15-2012, 03:55 PM   #2
Rewards Points: 1,542
The multiwire branch circuit will work fine. Just double check to be sure that when you hook it up at the panel that the two sides have 240 volts across them (not 0 volts)
Old 10-15-2012, 03:57 PM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Your lights may not care, but your future electric gate will care. Spend the extra money now or later, it really doesn't matter, but the gate will need larger wire.
Old 10-15-2012, 04:07 PM   #4
Rewards Points: 502
Most of the controllers I am familiar with for residential applications have a max draw of 5 amps, so @280' that would be a voltage of 114.
The chances of us putting a gate in, are low, but one can dream
-Andrew
DIY hobbiest
Old 10-15-2012, 04:28 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
Use a 2 pole breaker for your MWBC and you will not have to worry about this issue (it is a code requirement to use a 2 pole or 2 single poles with handle ties).
Use a battery powered gate opener and use the AC to run a battery charger.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 10-15-2012, 05:26 PM   #6
Oso954's Avatar
Rewards Points: 1,354
I would rather run one full power circuit rather than 2 weak ones. You never know what you will want to plug in there, after it is there.
I would use a #8. If I was worried about a the possible 2nd circuit, I would bury a 2nd conduit in the trench.
Oso954 is online now   Reply With Quote
Old 10-16-2012, 10:50 AM   #7
Rewards Points: 502
Thanks all for your input.
-Andrew
DIY hobbiest
Swithced Outlet to Ceiling Light/Fan Troubles adamiano86 Electrical 7 01-29-2012 09:36 PM
Odd Fireplace Outlet Behavior permagrin Electrical 2 12-17-2011 08:06 AM
Switched outlet series Overkll Electrical 4 12-07-2010 07:38 AM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 08:38 PM
Help Help richie02 Electrical 7 06-17-2008 08:42 AM
