-   -   Outlet - 220' underground Run - MWBC (http://www.diychatroom.com/f18/outlet-220-underground-run-mwbc-160198/)
AndrewF 10-15-2012 04:51 PM
I have a 220' conduit run from the house to the end of the driveway that I want to finally pull electric thru for Christmas lights, etc.
The total distance run from there to the panel, will be in the neighbor hood of 280'.
My initial plan was to pull a single circuit with #12, but now I am considering making it two circuits.
So long as I put each circuit on a separate phase in the panel, I can share the neutral, correct?
Someday we might put a gate out there, so I might as well run the second circuit now.
So I can pull 4 #12 wires (2 blacks, 1 white and 1 green)?
Voltage drop will be acceptable for this purpose, especially since bumping up to #10 increases the cost by $40 per run when considering that I'll purchase 4 - 500' spools. (A $200 difference)
I did a voltage drop calculation and for #12 at 15 amp load for 280' gives me a voltage of 106. In the past, we have used #14 cords to handle probably 10 strands of lights and I think that only pulled 5 amps.
I dont care if the Christmas lights get 106v instead of 120, especially considering LED strings pull less.
AllanJ 10-15-2012 04:55 PM
The multiwire branch circuit will work fine. Just double check to be sure that when you hook it up at the panel that the two sides have 240 volts across them (not 0 volts)
k_buz 10-15-2012 04:57 PM
Your lights may not care, but your future electric gate will care. Spend the extra money now or later, it really doesn't matter, but the gate will need larger wire.
AndrewF 10-15-2012 05:07 PM
Most of the controllers I am familiar with for residential applications have a max draw of 5 amps, so @280' that would be a voltage of 114.
The chances of us putting a gate in, are low, but one can dream :)
rjniles 10-15-2012 05:28 PM
Use a 2 pole breaker for your MWBC and you will not have to worry about this issue (it is a code requirement to use a 2 pole or 2 single poles with handle ties).
Use a battery powered gate opener and use the AC to run a battery charger.
Oso954 10-15-2012 06:26 PM
I would rather run one full power circuit rather than 2 weak ones. You never know what you will want to plug in there, after it is there.
I would use a #8. If I was worried about a the possible 2nd circuit, I would bury a 2nd conduit in the trench.
AndrewF 10-16-2012 11:50 AM
Thanks all for your input.
