Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 03-09-2013, 06:10 PM   #1
beginner50's Avatar
Outlet
I have no electrical outlets in either my down or up stairs bathrooms, can I run wire from the vanity light down to where I want my outlet?? I have no experience with such things but that's why I'm here. Also every bedroom and room except kitchen and dining room have one little light right byvthe door. How can I place different fixtures in each?? Thanks
beginner50 is offline   Reply With Quote
Old 03-09-2013, 06:26 PM   #2
Rewards Points: 83
A bathroom with no receptacle do you have a pull chain light?
Its possible.
You run the risk of having the receptacle being switched by the light switch depending on how it is wired.
What ever you do make sure it is a GFCI.
Do you have access in the attic or basement?
mech_gui is offline   Reply With Quote
Old 03-09-2013, 06:30 PM   #3
Rewards Points: 13,724
Just a few guesses.
Really old house.
60 amp, panel.
May even have old knob and tube wiring.
Time for a pro real electrition.
Not a friend of a frenid who have done this before to try and save a few bucks.
Old 03-09-2013, 08:03 PM   #4
joed's Avatar
Rewards Points: 12,878
You need to add your location. Bathroom receptacles must be on a 20 amp circuit that serves only the bathroom or that serves only bathroom receptacles from different bathrooms.
Old 03-09-2013, 08:16 PM   #5
Electrical Enthusiast
Rewards Points: 504
Could you provide some more information about the age of your house, wiring type (if you can tell), etc.?
Kyle_in_rure is offline   Reply With Quote
Old 03-09-2013, 08:19 PM   #6
Rewards Points: 83
you know that it is K&T or mineral fiber. Wire too short, brittle blech
I'd run new if I I had room in the panel.
Old 03-09-2013, 09:04 PM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Regardless, if the home is old enough that there are no receptacles in the bathrooms it is definitely safe to say he CANNOT run receptacles off the vanity light wiring.
If you have no experience with wiring now is not a good time to start. This is more of a project than a beginner should attempt. You'll need to run a line from your panel to the bathroom for these receptacles.
The Following User Says Thank You to Speedy Petey For This Useful Post:
Stubbie (03-09-2013)
Old 03-09-2013, 09:08 PM   #8
beginner50's Avatar
1915 built home. The vanity light that was previously in the downstairs bath had a plug in. The wires that were used for the old vanity I used for our new vanity but I have no idea about the rest.
Old 03-09-2013, 09:12 PM   #9
Rewards Points: 83
I'm starting to feel the age of the home.
I would look into a a main panel upgrade possibly doing some re-wiring. I agree with speedy this DIY project could go south really fast.
Old 03-09-2013, 10:20 PM   #10
Rewards Points: 504
Your best bet is to call an electrician. Running receptacles to bathrooms requires new circuits.
Outdoor Outlet seansy59 Electrical 3 03-09-2012 03:50 PM
Swithced Outlet to Ceiling Light/Fan Troubles adamiano86 Electrical 7 01-29-2012 09:36 PM
Switched outlet series Overkll Electrical 4 12-07-2010 07:38 AM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 08:38 PM
Help Help richie02 Electrical 7 06-17-2008 08:42 AM
