Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 11-15-2012, 08:46 PM   #1
Outlet
Today I had problem in ac/heater. They have 20amp250v plug and cord both burn out. I went to Meanders and I get 20amp Cord and Cooper Wiring Devices 20-Amp 250-Volt Commercial Grade Straight Blade Single i fixing it but still my ac/hetaer did not work
imp12 is offline   Reply With Quote
Old 11-15-2012, 09:24 PM   #2
Licensed electrician
Rewards Points: 1,010
Do you have the proper voltage at the receptacle? If you do the problem could be in the heater. If not a connection may have failed upstream of the receptacle in use.
Switched Outlet Issue mjm Electrical 13 06-14-2015 08:56 PM
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 05:14 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 10:13 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 04:36 PM
