Outdoors Sub Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 08-17-2012, 07:32 AM   #1
Outdoors sub panel
I have 3 appliances I use on my Volunteer concession stand. One at 110v- 1500 watts, one at 1200 watts, one at 1000 watts plus some low wattage lighting.
Right now I run extension cord for each appliance.
I would like to know if a breaker panel can be used to split up outlets using one heavy cord like on a 30 amp RV cord?
I use these outdoors most of the time under a Ez-Up tent. Need input on desired panel and breakers to use. Yes they will be ground fault breakers or outlets.
Gregad511 is offline   Reply With Quote
Old 08-17-2012, 07:58 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
Yes you can do as you suggest but where would you plug in your 30 amp cord? It would require a dedicated 30 amp receptacle at the site.
Coastal South Carolina
Old 08-17-2012, 08:11 AM   #3
Would use a RV site 30 amp when available. I know I would have to run more cords from 15 or 20 amp standard outlets on separate breakers anyway but want them reduced down to 15 amp at my tables. What would you suggest for a panel? Steel? or something else?
Old 08-17-2012, 08:48 AM   #4
A "Handy Husband"
rjniles's Avatar
Here is a 4 space outdoor load center.
http://www.homedepot.com/h_d1/N-5yc1...1#.UC5J9KBzCjI
Install 3 (or 4)15 amp circuit breakers and wire out to GFCI receptacles. Use SOJ 10-3 cordage with a TT30 plug to feed this panel. This is very much like how a RV is wired.
Old 08-17-2012, 10:09 AM   #5
Master Electrician
Are those the actual load wattages? If so at 120v your at 31a. The rv cord isn't going to cut it.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 08-17-2012, 10:15 AM   #6
A "Handy Husband"
rjniles's Avatar
Depends on whether everything runs at the same time, What are the 3 appliances?
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 07:24 AM
Panel cleanup gdoucette Electrical 5 06-26-2010 02:01 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
