Outdoor Wiring To Pool Pump - Electrical - DIY Chatroom Home Improvement Forum
Old 06-09-2008, 09:19 PM   #1
Question
Outdoor wiring to pool pump
I live in Upstate NY. I have a deck that is attached to the house. The deck runs about 25 feet from the house to an above ground pool. I bought a new pump that I have to run AC to. Can I run outdoor rated cable from the box in the house along the underside of the deck, maybe stapling it to the deck rafters to an outlet somewhere close by the pump?
Thanks,
Steve
svanvolk is offline   Reply With Quote
Old 06-09-2008, 09:34 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
No, the ground wire has to be insulated. The receptacle has to be at least 10' away and gfci protected with an "in-use" cover. It can be between 5 & 10 by meeting other standards which I won't go into unless you want You can run conduit outside to a junction box inside then you're allowed to go to "cable" and no smaller than #12
wirenut1110 is offline   Reply With Quote
Old 06-09-2008, 09:38 PM   #3
Rewards Points: 510
P.S. We're going by 05 code so I don't know if you're locale is going by '08 and if this changed in that code
Old 06-10-2008, 06:03 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Wirenut is right on.
You can run conduit under the deck. Anything out side MUST be conduit with individual conductors for ALL of the outside portion of the wiring to a pool motor.
Are you familiar with ALL the other codes regarding wiring and bonding a pool????
Old 06-10-2008, 06:15 AM   #5
After I posted the question, I browsed the similar posts and was convinced that I would have an electrician do it. I have done a lot of indoor wiring. But I certainly do not know enough to wire outdoors to the pool pump. After all, safety's first.
Thanks guys!
Tags
outdoor wiring , pool , pump
Noisy pool pump? DIYtestdummy General DIY Discussions 38 10-01-2014 08:26 AM
pool pump BillyD Plumbing 4 05-12-2008 10:07 PM
swimming pool pump wire steel Electrical 5 04-06-2008 08:35 PM
Just to confirm, no GFCI needed for hard wired pool pump..right?? Al the Diy guy Electrical 6 02-10-2008 12:28 PM
GFI Breaker & pool pump mitchman333 Electrical 7 05-08-2006 05:32 PM
