Outdoor Weatherproof Outlet Box Wiring... - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-13-2014, 06:02 PM   #16
Rob
Robpo's Avatar
Rewards Points: 826
Originally Posted by justintoo1 View Post
The wire appears to read this...
Not sure if that's correct, nor what it means. But some googling...
http://www.southwire.com/products/RHHRHWUSEOEM.htm
Is it USE (Underground Service Entrance) type wire, manufactured by the 'CIRCLE WIRE & CABLE CORP', and a 12 gauge solid wire...right?
thanks -j
It is not your service entrance wire but if that is what it says than that is what it is. If it is in good condition it can be used for the GFCI.
Robpo is offline   Reply With Quote
Old 06-13-2014, 06:07 PM   #17
Rewards Points: 3,396
Hi again,
Here's my idea of my finished product.
That bottom left text says 'underground run 12 inches deep'.
Then I'll grab 2ft PVC grey conduit and drop it atleast 1ft under. Run the wires up through. I'll connect the PVC conduit to the outlet box.
Seems about right? - j
If you're thinking about running the 2 wires that are there with no ground. not buried to the proper depth and not protected, not direct burial cable? That's up to you.
The job you doing is "hack" against all codes and dangerous..
So I wouldn't look for advice here on how to try to make those conductors work for you.
ritelec is offline   Reply With Quote
The Following User Says Thank You to ritelec For This Useful Post:
gregzoll (06-13-2014)
Old 06-13-2014, 06:07 PM   #18
NO it can't
the whole install is wrong
Old 06-13-2014, 08:59 PM   #19
Rewards Points: 41
Hi,
Ok - so 18 inches, UF, in PVC conduit?
EDIT: or 24 inches direct burial..?
Is that proper?
I'm not really reference any NEC, but just googling.
I think I should be able to pull/fish the UF cable through the run.
Am I starting to get things correct?
Let me know, thanks - j
justintoo1 is offline   Reply With Quote
Old 06-13-2014, 10:02 PM   #20
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
If you run the wire in pvc pipe from start/finish outside it doesnt need to be uf cable.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 06-14-2014, 08:19 AM   #21
24, 18, 12, or 6
check this chart for your application
http://www.xwalk.com/images/Table_30...over_Reqts.pdf
don't mean to bust your horns.
To code or not, there are installs that may not be to the current letter of the law to the code, but at one time where, or considered a calculated risk.
What you where/are proposing with the existing was too wrong.
A shovel, a nice day, radio, couple beers (or ice tea).. trench away
plummen (06-14-2014)
switch outlet combination phill1 Electrical 4 11-09-2013 08:57 AM
Wiring an outlet to a switch, to a light Athens Electrical 5 01-04-2012 07:03 PM
Help wiring new outlet Wnt2bsleepin Electrical 15 09-08-2011 11:53 AM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
Troubleshooting bedroom outlet wiring? Operator4819 Electrical 15 04-01-2007 08:10 PM
