Outdoor Weatherproof Outlet Box Wiring... - Electrical - DIY Chatroom Home Improvement Forum
Old 06-05-2014, 10:19 PM   #1
Rewards Points: 41
Outdoor weatherproof outlet box wiring...
Hi,
I had some old two wire just buried in my front yard that once was wired to a lamp post. Lamp post been gone since I moved in, and the buried wires were an eye sore.
So I dug them back to the bush line and plan to mount an outlet on my brick...
I bought an in-use weather proof box, receptical, and GFCI outlet...
So, can I use black plastic wire loom, or is this a case for pvc conduit?
I was going to just run the wires under ground to just below the box, and then have them run up ~8in to where I'm mounting the box to the brick.
Would that look alright? That's why I questioned the loom or conduit - you know to make it look more professional.
Thanks - j
justintoo1 is offline   Reply With Quote
Old 06-07-2014, 08:40 AM   #2
Rewards Points: 808
PVC conduit.
IslandGuy is offline   Reply With Quote
Old 06-07-2014, 09:05 AM   #3
Home Remodeler
Rewards Points: 164
No ground wire?
mikey48 is offline   Reply With Quote
Old 06-07-2014, 10:52 AM   #4
Rob
Robpo's Avatar
Rewards Points: 826
Older house?
Robpo is offline   Reply With Quote
Old 06-07-2014, 12:37 PM   #5
Home Remodeler
Rewards Points: 164
Yes it is old house but I would not use it unless it was grounded. I think by code if you are modifying the circuit it must be up to code.
Old 06-07-2014, 12:42 PM   #6
Rob
Robpo's Avatar
Rewards Points: 826
can you run a ground wire.
Old 06-07-2014, 01:15 PM   #7
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
The lack of a ground wire doesn't bug me since it will be gfi protected,My issue is the separate conductors not being rated for direct burial.
Is there a piece of conduit buried there someplace those wires were ran through origionally?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 06-07-2014, 08:41 PM   #8
Msradell's Avatar
Rewards Points: 172
Do you know where these wires come from? If so go back to the source and run new underground rated cable from there to where you want to put your outlet! Even if those existing conductors are rated for underground use they need to be in conduit. Also the new outside outlet needs to have a ground conductor as well as GFCI. Do it right or don't bother doing it. By the way, I'm hoping that the circuit of conductors on is already killed.
Msradell is offline   Reply With Quote
Old 06-07-2014, 08:43 PM   #9
Rewards Points: 6,652
If I had to make a fair guess. Those wires appear to be Low Voltage wiring.
Old 06-13-2014, 04:24 PM   #10
Rewards Points: 41
Hi there,
Sorry for the no replies, away on vacation.
Now back to reality...(lol)
-No ground wire.
-Older house, yes ~1964.
-Buried. Yes. No conduit. Run from inside my basement furnace room, into a junction box, out of it and through the concrete to the outside. I'm assuming it runs under the drive way to the front yard. Was buried in no conduit under the front year to the former lamp post location.
-Yes. Killed. They are disconnected within the junction box that they run from in the basement. Both have two wires, wire nut and tape.
I wondered about the GFCI and the lack of a green/bare ground wire.
My 'old' house has two-wire. So if I were to run 3-wire out to my outlet box, what does the ground connect to? I'm thinking I could dig it up until it goes under the concrete, run it through conduit, up and out into the box.
thanks - j
Old 06-13-2014, 04:50 PM   #11
You need to run correct wire from your panel to the light. UF is preferable. As stated before. That appears to be 12vDC Low Voltage wiring or someone ran THHN/THWN without conduit. Having an old house is like a present from your grandmother. You never know what you are going to run into, or find as you peel back the layers of problems, previous owners of the home have done.
The Following User Says Thank You to gregzoll For This Useful Post:
justintoo1 (06-13-2014)
Old 06-13-2014, 05:39 PM   #12
Rewards Points: 41
The wire appears to read this...
TYPE USE-STYLE RR-CIRCLE WIRE & CABLE CORP SIZE 12 SOLID
Not sure if that's correct, nor what it means. But some googling...
http://www.southwire.com/products/RHHRHWUSEOEM.htm
Is it USE (Underground Service Entrance) type wire, manufactured by the 'CIRCLE WIRE & CABLE CORP', and a 12 gauge solid wire...right?
thanks -j
Old 06-13-2014, 05:52 PM   #13
Rob
Robpo's Avatar
Rewards Points: 826
Originally Posted by justintoo1 View Post
Hi there,
thanks - j
Is there a ground screw on the junction box and is there a metal cable going to the J-box from the panel box?
The Following User Says Thank You to Robpo For This Useful Post:
Old 06-13-2014, 05:58 PM   #14
Rewards Points: 41
Hi again,
Here's my idea of my finished product.
That bottom left text says 'underground run 12 inches deep'.
Then I'll grab 2ft PVC grey conduit and drop it atleast 1ft under. Run the wires up through. I'll connect the PVC conduit to the outlet box.
Seems about right? - j
Old 06-13-2014, 06:01 PM   #15
Rewards Points: 3,396
Looks like someone direct buried some rhw wire.
So, rip it out, or disconnect it tape it up and leave it.
What are you thinking about doing?
Layout and do the job like the rhw never existed.
UF or conduit with conductors.
Time to move on.
ritelec is offline   Reply With Quote
The Following 2 Users Say Thank You to ritelec For This Useful Post:
gregzoll (06-13-2014), justintoo1 (06-13-2014)
switch outlet combination phill1 Electrical 4 11-09-2013 08:57 AM
Wiring an outlet to a switch, to a light Athens Electrical 5 01-04-2012 07:03 PM
Help wiring new outlet Wnt2bsleepin Electrical 15 09-08-2011 11:53 AM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
Troubleshooting bedroom outlet wiring? Operator4819 Electrical 15 04-01-2007 08:10 PM
