Outdoor Weatherproof Boxes With PVC Conduit - Electrical - DIY Chatroom Home Improvement Forum
Old 07-25-2012, 11:24 AM   #1
Rewards Points: 242
Outdoor weatherproof boxes with PVC conduit
Want to install an outdoor outlet which will be used for a radio or weed whacker(no swimming pool) on a 4x4 post near the edge of my patio.
Can the following die-cast aluminum outlet box shown here: http://www.grainger.com/Grainger/BELL-Weatherproof-Single-Gang-Outlet-Box-3KG83?Pid=search be used with PVC conduit.
collegetry is offline   Reply With Quote
Old 07-25-2012, 11:44 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 382
Yes it can.
Old 07-25-2012, 12:30 PM   #3
Licensed electrician
Rewards Points: 1,470
Why don't you look at the Garden post by Arlington? This is a one piece box and post all in one.
aifittings.com
Old 07-25-2012, 12:50 PM   #4
Rewards Points: 242
Never seen it before but would look better than a 4x4 post. Have you ever installed one? Does it just push into the ground. Do you run the PVC conduit up into it or is UF cable used?
Old 07-25-2012, 01:09 PM   #5
Depending on your soil you might be able to push it into the soil or you might need to dig.
Type UF or a conduit can be used on the post. There is a removeable plate that the connector installs in.
I think they are a nice product and they do not rot.
k_buz (07-25-2012)
Old 07-25-2012, 01:12 PM   #6
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Nothing just pushes into the ground, you dig a hole and set it in place, you can use PVC or UF. The post is the electrical box.
Old 07-25-2012, 02:42 PM   #7
Rewards Points: 242
Is this removeable plate on the inside of the post so that the UF or conduit enters inside the post or is the plate on the outside(or one of the faces of the post)
On the outside doesnt make sense becuase I know I could not run UF up the outside of the post.
Just not understanding how the the "supply" whether it is UF or PVC conduit terminates at the post.
Old 07-25-2012, 02:46 PM   #8
The plate fits inside the post and becomes the bottom of the junction box. There are knockouts in plate to allow the connectors. The plate gets secured to the post with a small screw from the outside.
If you look at this picture, the plate mounts where the low voltage divider is shown.
http://www.aifittings.com/catalog/we...fixtures/GP19B
Old 07-25-2012, 05:31 PM   #9
Rewards Points: 242
But your supply whether it be a UF cable or conduit runs up the inside of the post and will secure to this plate you are referring to?
I have looked all over the internet to try and find a photo of the insid eof the post or this p[late.
Old 07-25-2012, 05:50 PM   #10
Yes, the post can slide over the conduit or cable.
The plate is just a square with two knockouts for 1/2" connectors in it.
Old 07-25-2012, 06:09 PM   #11
Rewards Points: 242
thanks Jim heres a nother question. Can the weatherproof outlet box be attached directly to the 5x5 vinyl fence post instead of setting a 4x4 wooden post next to the end post and attaching the outlet box to the wooden post?
Outdoor weatherproof boxes with PVC conduit-fence-columbia-white-ctf07pbtfwvsp0023a.jpg
Old 07-25-2012, 06:49 PM   #12
I don't see why not. Some would consider that conduit to be subject to damage leaving the ground and would requires Schedule 80 PVC.
Old 07-25-2012, 06:55 PM   #13
E2 Electrician
I concur, that installation is more than adequate, heck, run the pvc pipeline down the fence.
Old 07-26-2012, 08:23 AM   #14
Rewards Points: 242
So use scedule 80 PVC instead of 40?
Old 07-26-2012, 09:11 AM   #15
Licensed Pro
One change I would make to your plans if you decide on the WP box/conduit... use a PVC box instead of a metal one. Over time the metal ones will leak and corrode.
Joining romex and conduit Restyle Electrical 2 11-08-2011 03:01 PM
terminating conduit connection between house and detached shed amakarevic Electrical 11 06-30-2011 08:51 PM
GFCI Panel Conduit Question passmaster16 Electrical 1 06-08-2011 10:28 PM
Buried gas pipe in conduit WillK Plumbing 4 01-07-2011 12:50 PM
garage conduit question b_corwin Electrical 19 04-16-2010 12:32 PM
