Outdoor Wall Lights With Junction Box - Electrical - DIY Chatroom Home Improvement Forum
Old 01-04-2013, 08:56 PM   #1
Rewards Points: 12
Outdoor wall lights with junction box
I pulled off one of two outdoor wall lights that surround my front door. Turns out they were installed without a junction box. From reading, this leaves me with a few options:
  1. Disconnect the wiring and leave as decoration only (I have access to inside walls).
  2. Mount round boxes (hole saw, screws from inside of box to stud, wiring coming in from back of box). This gets complicated because the siding won't allow the light to mount flush.
  3. Find a wall light that allows the use of an exterior wet-location box. I haven't found any of these.
Thoughts?
rbaevergreen is offline   Reply With Quote
Old 01-04-2013, 09:29 PM   #2
" Euro " electrician
frenchelectrican's Avatar
Thoughts?
Well for the first option don't bother with that one for a moment I will fill ya in a second.
For second option there are couple way you can do this one is old school methold which you will of course use the hole saw and old work box or use the modern item which the Arington did make a sliding adpator to fit on surafce which you can really elemated rest of the hard work on that.
Here one verison.,
Here the second one
Both should be aviable in most of the big box store otherwise electrique supply centre will have this stock or order one for you.
Just be aware there are few differnt verison of that adpator as I posted above so make sure you get the correct one.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
NJMarine (01-05-2013)
Old 01-05-2013, 12:19 AM   #3
Rewards Points: 13,300
What type siding do you have?
Old 01-05-2013, 06:36 PM   #4
Rewards Points: 12
I will have to take measurements, but if you search PG4004H at The Home Depot it will give the general idea.
Elaborate Plan for wiring my theater lighting danielrg Electrical 21 04-05-2013 06:26 PM
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 09:52 AM
Changing from florecent lights to canned lights, currently 2 sets of wires & I need 4 clueless@wires Electrical 2 04-16-2012 07:21 AM
Ceiling and Exterior Wall Lights tmc8203 Electrical 1 12-05-2009 04:03 PM
Low profile junction box or distribution block for line voltage undercabinet lights ? Bluelude1 Electrical 2 05-01-2008 08:52 PM
