Outdoor Surface Mounted Electrical Box - Electrical - DIY Chatroom Home Improvement Forum
Old 10-15-2012, 09:00 AM   #1
outdoor surface mounted electrical box
Hi again we really enjoy all this info.....we have an issue of our own though..we have a new sunroom that has a surface mounted electrical box for the lighting..cannot find any fixtures that have small enough backplates to fit all will be overlapping sides and top of backplate is there some kind of adapter plate to cover open area behind backplate???
Kennjan2012 is offline   Reply With Quote
Old 10-15-2012, 09:13 AM   #2
Rewards Points: 13,444
Without a picture of what you have hard to let you know how to fix it.
Is this a vinyl siding siding block?
Lowes and Home Depot have simple to install backing plates that set right over what you most likly have now for larger lights like that.
Just remove the trim ring and the new cover slips right in the same place.
Kennjan2012 (10-15-2012)
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 09:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 02:42 PM
Changing from Electrical Cook Top to Electrical Range EkS Electrical 24 06-22-2010 10:43 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
