Old 01-02-2009, 02:43 PM   #1
outdoor recpticles
Could anyone please tell me what type of cover is required for outdoor plugs that have a patio roof over them. I'm aware of the gfci requirement but I hope I don't have to have that "in use" cover on these like the ones I placed elsewhere around the outside of the house. It's just a matter of aesthetics and practicality for the power around a beautiful new deck.
Thank's and peaceful new year to all
I'm gonna hurl myself against the wall
because I'd rather feel bad than not feel anything at all
Warren Zevon
handifoot is offline   Reply With Quote
Old 01-02-2009, 02:50 PM   #2
outdoor recpticles
Code will require an in use cover.
They are obtrusive though onless they are the recessed kind.
Just take it out after inspection.
*****did I say that outloud?*****
220/221 is offline   Reply With Quote
Old 01-03-2009, 01:53 PM   #3
J. V.'s Avatar
outdoor recpticles
Yep, you did.
He may not need that cover as he has a roof over the receptacle. There is some exception regarding the roof line angle in respect to the height of the receptacle. I am pretty sure he can use a regular outdoor GFCI cover. I think?
Old 01-03-2009, 02:05 PM   #4
Electrical Contractor
kbsparky's Avatar
outdoor recpticles
It depends on whether you are dealing with a "wet" location or a "damp" one.
A covered porch outlet if located far enough under roof is not considered a "wet" location if it is unlikely that rain/snow/etc can get to it under normal conditions. If that is the case, then a flat cover may be used.
One thing to consider using is a recessed box, which has the best of both worlds: Flat cover, and ability to close it while in use:
Old 01-03-2009, 02:07 PM   #5
Res Ipsa Loquitur
outdoor recpticles
If you can find out from your inspector first it might save you a headache of what they want- otherwise, you can cinsider what 220/221 suggested. Also, less obvious (recessed) covers are made by Arlington.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 01-03-2009, 03:48 PM   #6
Electrician
outdoor recpticles
Nope I didn't hear you say a thing, your keyboard on the other end is acting kind of strange, typeing messages you obivously didn'y mean to send..
darren is offline   Reply With Quote
