Outdoor Recessed Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 06-08-2011, 12:15 PM   #1
Rewards Points: 358
We have a VERY small covered porch, 24"x48" and right now we just have a regular porch light on the wall. Me and the wife got to thinking we should remove the porch light and install a single recessed bulb in the middle.
The wiring is simple, I know how that works, but my question is because this is a covered porch can I just use the typical recessed fixture like you would find at HD or Lowes? Its not open to the elements so I would expect it to be ok, and it will not get any more moisture in it than the recessed lighting in my bathroom, or so I would think?
cbzdel is offline   Reply With Quote
Old 06-08-2011, 01:16 PM   #2
Electrician
SD515's Avatar
Rewards Points: 504
Typically if it’s a covered porch and not completely enclosed, the underside where you would mount the recessed would be considered a damp location. Many recessed cans are listed for damp locations, but check first just to be sure.
Kyle
Old 06-08-2011, 01:20 PM   #3
Rewards Points: 358
Ok thanks! What is is called if its rated for in contact with insulation? We have blow in attic insulation and I dont want to box around it. I think its called IC rated?
Old 06-08-2011, 01:28 PM   #4
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 686
Yes IC rated = Insulation Contact. FWIW, I have 3 recessed lights on my front porch with no problems - other than they seem to burn out bulbs faster than my other fixtures. I didn't put them there though, so I can't tell you what kind/type they are.
hyunelan2 is offline   Reply With Quote
Old 06-08-2011, 01:32 PM   #5
Electrician
SD515's Avatar
Rewards Points: 504
IC is rated for direct contact with insulation, Non-IC is not rated for direct contact with insulation (minimum space around fixture would have to be maintained).
Kyle
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 10:47 PM
General design and lighting? mrs1885 Landscaping & Lawn Care 14 01-06-2011 04:12 PM
Lighting Options for a dropped ceiling basement markronz Electrical 11 04-20-2010 03:20 PM
lighting a covered, enclosed patio (cross-posted in electrical) 1655graff Remodeling 1 11-21-2007 01:45 PM
lighting a covered, enclosed patio 1655graff Electrical 5 11-21-2007 09:06 AM
