Outdoor Receptacles - Electrical - DIY Chatroom Home Improvement Forum
Old 08-12-2013, 07:46 PM   #1
Rewards Points: 150
Quick question. I'm adding some outdoor outlets, gfi protected and outdoor covers of course, but I was wondering if they have to be dedicated or can I tap into an indoor circuit. I'm adding about three. I live in western pa. Thanks
romex1220 is offline   Reply With Quote
Old 08-12-2013, 08:07 PM   #2
Master Electrician
Rewards Points: 3,820
You can tap into general purpose circuits. Not circuits such as laundry, bath receps, kitchen countertops and a few others.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
Jim Port (08-12-2013)
Old 08-12-2013, 08:52 PM   #3
Rewards Points: 150
I'll probably just run a dedicated circuit with one gfi and have the other two feed through it so I don't have to buy three gfi outlets.
The Following User Says Thank You to romex1220 For This Useful Post:
oh'mike (08-13-2013)
Old 08-14-2013, 04:57 PM   #4
Rewards Points: 170
check your local code, but around here (Wisconsin) all outdoor outlets MUST be on their own dedicated 20 amp circuit in order to provide enough power for electric yard tools such as trimmers, edgers, etc. in addition to any other items you may have plugged in. If adding a 20 amp circuit is not to difficult for your situation I strongly advise it. 3 outlets can be quit a bit when outside and especially when added to 14-2 circuits that ALREADY power things inside.
Good luck on your project!
diyer111 is offline   Reply With Quote
The Following User Says Thank You to diyer111 For This Useful Post:
romex1220 (08-14-2013)
Old 08-14-2013, 05:13 PM   #5
Rewards Points: 150
Thanks diyer. I got them wired already with 12/2 on a 20 amp circuit. Checked local codes and they allow you to tap into general use circuits.
