Outdoor Receptacle Requirements - Electrical - DIY Chatroom Home Improvement Forum
Old 09-21-2010, 03:37 PM   #1
outdoor Receptacle requirements
Can you put 30A/120v receptacle outside the building? If so, what are the requirements?
Does it have to be GFI? or can we use a seperate GFI breaker?
or locable switch?
diptipatel78 is offline   Reply With Quote
Old 09-21-2010, 03:45 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,942
You can, and it does not have to be GFI unless you want to. A GFI breaker would be the only way since a 30A GFI receptacle does not exist.
Old 09-21-2010, 09:16 PM   #3
" Euro " electrician
frenchelectrican's Avatar
Is this going to be used with the RV ??
If so you will need two gang weatherproof box due the recetpale is bigger than the standard size recetpales are.
They are simauir to dryer but the blade format is not the same
Here the photo what it look like.
That will give you the idea what the RV common receptale look like.
You can see the size of the device so you can use one gang but will be hard to find a cover to fit the opening otherwise the two gang weather proof device will have a opening to fit it.
Merci.
Marc
Difference between 220 and 240 volt requirements? cleveland Electrical 7 04-14-2010 07:24 AM
electrical requirements for large whole home system jumonji Electrical 6 02-23-2010 01:41 AM
Code requirements for low voltage wiring in conduit with 120V flyboy Electrical 9 12-24-2009 06:48 PM
Requirements for Granite? jerome8283 Interior Decorating 2 01-02-2009 04:05 PM
What are the joist requirements for a tile floor? slatergrl Flooring 8 07-16-2008 10:08 AM
