Outdoor Receptacle Box Question - Electrical - DIY Chatroom Home Improvement Forum
Old 10-17-2010, 08:07 PM   #1
RST
DIY Homeowner
Rewards Points: 150
The previous owner installed an outdoor receptacle through the siding into an old work box. I've already ripped out all of his other electrical work, so I suspect this also needs fixed. It is not GFCI protected now, but it WILL be when I finish rewiring the garage. (Right now it's disconnected.) A few questions:
(1) It only has a flip cover. As I understand things, it should have an in-use cover instead. Correct? (NEC 2008 in my jurisdiction.)
(2) Do I also need to replace the box with some sort of outdoor rated box?
(3) If so, can someone recommend an alternative to a Bell box? I'm looking for something subtle since it is the front of the house. I put a Bell box on the back and it is bulky with the cover on!
Thanks,
Robert
RST is offline   Reply With Quote
Old 10-17-2010, 08:18 PM   #2
Licensed electrician
Rewards Points: 1,622
Yes, some sort of weatherproof in use cover would be required.
I like these better than the bubble covers. http://www.arlcatalog.com/Weatherpro...nstruction.htm
The box only needs to be WP if it is exposed.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
DangerMouse (10-18-2010), RST (10-18-2010)
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
