Outdoor Receptacle - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-13-2013, 09:03 PM   #16
Originally Posted by joecaption View Post
Where are you getting the power from?
If it's a close by inside outlet your tapping off of, concider installing the GFI in that box.
Reason being is there's less chance of faulse trips from moisture.
As expencive as wire is it may be cheaper to use two GFI instead of a long run of wire.
I am running a new 20 amp circuit from the panel
POWER STROKE is offline   Reply With Quote
Old 04-13-2013, 09:05 PM   #17
Originally Posted by AandPDan View Post
Make sure to use weather resistant outlets and GFCI's for your outdoor locations.
NEC 406.8
Sure will, Thanks for the reply and help
Old 04-13-2013, 09:07 PM   #18
Originally Posted by hammerlane View Post
Make sure you purchase weather resistant receptacles for outside.
Sure will Thanks for the reply
Old 04-13-2013, 09:09 PM   #19
Thanks every one for your help and replies
