Outdoor Receptacle - Electrical - DIY Chatroom Home Improvement Forum
Old 04-12-2013, 09:59 PM   #1
Outdoor Receptacle
I am in the process of installing 2 new 20 amp outdoor receptacles, one by the front door and one by the back door. my question is can I use a gfci in one box and come off of that with a regular receptacle in the other and still pass code. or do I need to use 2 gfci. Thanks in advance for any help.
POWER STROKE is offline   Reply With Quote
Old 04-12-2013, 10:14 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You can line/load multiple outside receptacles. Don't forget the in-use (bubble) cover.
Old 04-12-2013, 10:17 PM   #3
Yup i forgot to add that thanks for the reply and help.
Old 04-13-2013, 07:15 AM   #4
Rewards Points: 13,978
Where are you getting the power from?
If it's a close by inside outlet your tapping off of, concider installing the GFI in that box.
Reason being is there's less chance of faulse trips from moisture.
As expencive as wire is it may be cheaper to use two GFI instead of a long run of wire.
Old 04-13-2013, 07:17 AM   #5
k_buz's Avatar
Not true.
1) Moisture will affect a GFI device the same as a GFI protected receptacle.
2) If the GFI is tripping due to moisture, it is not a "false trip".
The Following User Says Thank You to k_buz For This Useful Post:
jbfan (04-13-2013)
Old 04-13-2013, 09:04 AM   #6
Rewards Points: 760
Make sure to use weather resistant outlets and GFCI's for your outdoor locations.
NEC 406.8
AandPDan is offline   Reply With Quote
Old 04-13-2013, 09:10 AM   #7
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I like to use a dead front GFCI inside and use standard weather resistant receptacles outside.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 04-13-2013, 09:16 AM   #8
k_buz's Avatar
Why? That makes no sense to me.
Old 04-13-2013, 09:18 AM   #9
Licensed electrician
Rewards Points: 1,760
Using two GFI receptacles does make it easier to reset should one of them trip.
Old 04-13-2013, 09:56 AM   #10
Electrical Enthusiast
Rewards Points: 504
I think it will come down to personal preference, really. If you use one gfci receptacle, any receptacle down the line will not have power when the gfci trips. If you use two independently wired gfci receptacles, only the affected gfci will be dead when it trips.
Kyle_in_rure is offline   Reply With Quote
Old 04-13-2013, 10:10 AM   #11
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
The company I work for installs GFCI's at every location, we don't LINE/LOAD GFCI's ever.... of course, our clients can afford this luxury, and it really makes troubleshooting a breeze.
Old 04-13-2013, 10:31 AM   #12
rrolleston's Avatar
I saw something like this in a house I did some work in. Had to have been at least eight just in the bathroom. They had two behind each sink in the double sink counter top and then a few more spread through the bathroom and the kitchen was huge and had to have and at least double that. I do like the idea of if one stops working it only affects one.
But eventually we will also have to deal with the whole kitchen being AFCI protected. I can imagine the calls will be crazy for troubleshooting and I don't mind taking them.
Old 04-13-2013, 10:33 AM   #13
Rewards Points: 504
Old 04-13-2013, 10:47 AM   #14
rrolleston's Avatar
Originally Posted by Kyle_in_rure View Post
Yup allot of changes coming in 2014. I am sure manufacturers are working on larger afci breakers so that regulations can be added to larger loads like dryers and ranges in future years. Nothing will surprise me when the government is involved.
Old 04-13-2013, 11:00 AM   #15
Rewards Points: 2,516
Make sure you purchase weather resistant receptacles for outside.
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
Kyle_in_rure (04-13-2013)
