Outdoor PVC To Panel Question - Electrical - DIY Chatroom Home Improvement Forum
Old 09-17-2010, 08:49 PM   #1
Outdoor PVC to panel question
Any advice on how to connect an outdoor 1" PVC pipe to the main house panel?
The 1" will have 3 6's and ground coming from a disconnect box and spa. The main panel is in a exterior wall on the outside of the home. I'm going to have to have to come in thru knock outs in the bottom of the panel and I can get the exterior PVC pipe less than a foot away from the panel.
One possible idea was an lb box to go inside the wall and then use smurf tube to the panel but I can't find 1" smurf tubing.
Any ideas?
Jonathan- is offline   Reply With Quote
Old 09-17-2010, 08:55 PM   #2
Just call me Andrew
Rewards Points: 1,020
First off, are you using gray PVC conduit (not white PVC pipe for plumbing)?
Andrew
secutanudu is offline   Reply With Quote
Old 09-17-2010, 10:22 PM   #3
Electrical Contractor
kbsparky's Avatar
You are doing this the hard way.
Simply cut a 1-3/8" hole through the back of the panel, directly to the outside. That is where you put the LB on the outside. You don't have to use the factory knockouts, you know.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
secutanudu (09-17-2010)
Old 09-18-2010, 02:59 AM   #4
I was planning on using the gray piping. Thanks.
I wish I could drill stright from the panel to the outside wall but the panel, like many homes in south cal, open from outside.
Old 09-18-2010, 10:08 AM   #5
Just call me Andrew
I don't know of any other kind!!!
Why not just run PVC all the way into the panel with pull elbows and the like, and just strap it to the wall?
Andrew
Old 09-18-2010, 11:57 AM   #6
Master Electrician
Rewards Points: 3,750
Use one of these with a lock nut and bushing.
brric is offline   Reply With Quote
Old 09-18-2010, 12:39 PM   #7
kbsparky's Avatar
How about posting a picture of your setup? If the panel is outside, it should not be a problem ... unless .... is that panel recessed into the wall, and only accessible from the outside?
-KB
Speedy Petey (09-18-2010)
Old 09-18-2010, 01:16 PM   #8
Glad you asked. The panel is recessed into the wall and opens from the outside.
Old 09-18-2010, 02:59 PM   #9
Licensed electrician
Rewards Points: 1,258
Can you switch over to seal tight conduit just below the panel anf transition into the wall into a KO? Sealtight is flexible like hose.
Old 09-18-2010, 03:19 PM   #10
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,874
Gotta love those dumb ass kalifornia panels.
Old 09-18-2010, 03:48 PM   #11
Yeah, they always seem so mellow. Way cooler than the outside panels in AZ, but not as cool as the panels in AK.
Old 09-18-2010, 05:24 PM   #12
Not a big fan of those outside panels either.
By seal type, do you mean the same thing as liquid tight?
I was thinking to use an LB box to enter the wall and then it's a sharp 90 to the panel bottom. Maybe to sharp for liquid tight.
Or do mean to change to liquid tight before entering the wall... Hmm.
Old 09-18-2010, 05:56 PM   #13
Use a 1" "Bushed Elbow" (sometimes known as a Telephone Ell) beneath the panel. That should get you out the outside wall. You might have to use a couple of 1" conduit nipples.
Bushed elbows come in 2 lengths, long and short Get the long one so that the conductors have bending room.
Put an LB on the end and you're home free!
http://www.electriciansupplies.com/p...03_ea9_tn1.jpg
alfred e neuman is offline   Reply With Quote
Tags
panel connection spa
Old House Rewire finnimus Electrical 15 05-13-2011 11:39 PM
panel clearance question MeanGene Electrical 1 09-14-2010 04:38 PM
Panel History (old Breaker Panel Question) jamiedolan Electrical 3 01-17-2009 04:27 PM
Service Panel Question??? sv123 Electrical 4 10-06-2008 07:26 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 11:27 AM
