Outdoor Post Light - Random Blinking Bulb - Electrical - DIY Chatroom Home Improvement Forum
Old 06-08-2010, 01:20 PM   #1
Question
Outdoor post light - random blinking bulb
Long time lurker, first time poster. Although not a contractor by trade I do consider myself above average in knowledge on most home repair/remodeling topics, but this one has me stumped.
I have an outdoor post lamp, single bulb, that goes on at dusk and off at dawn controlled by a sensor in the post. Not long after I got it (last Sept) I installed a CFL bulb. I had done this at a previous house and it lasted forever. This time however the light started going on and off at random intervals throughout the evening. Replacing the CFL bulb with a regular bulb worked for a while but then the blinking started again. This time I replaced the light sensor and everything has been fine for over 6 months.
A week ago I finally had to replace the bulb from all those months ago because it burned out. Within a few days of replacing it with the exact same make and model (60-watt) incandescent bulb the light has started randomly turning on and off again in the evenings.
Maybe it's the sensor again? I'm out of ideas.
handymike is offline   Reply With Quote
Old 06-08-2010, 01:35 PM   #2
Licensed Pro
Check the center contact in the bulb socket for corrosion and poor contact. WITH THE POWER OFF, use a small screwdriver or dentist's pick to clean the surface and gently lift the tab for better contact.
Old 06-08-2010, 01:44 PM   #3
Master Electrician
Rewards Points: 3,874
Are there any other nearby light sources that could be triggering the photo eye?
brric is offline   Reply With Quote
Old 06-08-2010, 01:51 PM   #4
HouseHelper - thanks for the corrosion tip. I'll check that out.
brric - I live in a typical newer subdivision so the other houses are close and so are their lights, but none of these other light sources have changed in the last few days.
Old 06-08-2010, 05:00 PM   #5
Sparkaholic
Rewards Points: 150
Send a message via Yahoo to sparks1up
Are you using one of those photocells that screw into the socket and then the lamp screws in on top of that?
Answers based on the mood I am in when you ask!
sparks1up is offline   Reply With Quote
Old 06-08-2010, 05:03 PM   #6
Nope. This is a standard threaded photo cell that resides in the lamp post, a few inches from the top of the post but below the light. Replacement photo cell came from Home Depot. Can't remember the brand. Maybe they only last 6 months??
Old 06-08-2010, 06:08 PM   #7
Master Electrician
Put some black tape over the photo cell for the night and see if the lamp still acts up.
Old 06-08-2010, 06:40 PM   #8
Does the sensor somehow see light from the controlled light?
If using a bulb with substantially higher wattage changes the symptom I'd say it was a bad connection.
Old 06-08-2010, 10:25 PM   #9
I'll try the black tape tomorrow (storms tonight) and see what happens.
The fixture is rated for a 100W bulb and I'm only using a 60 so there shouldn't be issues with too much light. And the light doesn't overhang the sensor so I don't anticipate an issue there.
Here is a link to the post light in question if that helps.
Old 06-14-2010, 01:29 PM   #10
Future reference for anyone with a similar problem.
The light completely stopped working a few days ago. I bought a new sensor thinking that was the problem. Turns out the GFCI had tripped because water somehow made it's way past the lamp and into the post, settling into the wire nuts which had their open ends conveniently (sarcasm) pointed in an upward direction. I'm glad I replaced the sensor because it enabled me to find the wire nut issue (fixed by keeping closed end of wire nuts facing up and wrapping with electrical tape). I also found the ground wire connection was completely corroded inside the wire nut and likely contributed to the sporadic behavior of the light in the first place.
Everything is working fine now. Cheap fix and good learning opportunity.
Amana roll out switch light blinking butter99 HVAC 2 04-02-2010 10:19 PM
Blinking low voltage light nickdu Electrical 11 11-09-2009 09:09 PM
Do they make light bulb converters that will still allow a light bulb? jimithing78 Electrical 15 11-28-2008 11:57 PM
Light Socket Won't Hold Light Bulb colhollywood Electrical 3 08-16-2008 08:28 AM
Do I need training to change a light bulb? Mechelle Electrical 11 08-13-2008 07:26 AM
