Outdoor Post lamps
I had taken off the top of the post, and used a line tester to check for power to the lamp. There is no power at the top of the wire, so the problem is before any connections at the top. The lights are controlled by a timer box in the garage, so I would assume that there is underground wiring from the box to the first post, and then to each successive post. There are no eyes involved nor is it a HID fixture. These are posts that are likely 15-20 years old, and I could understand if an end lamp were out, but a middle one with no juice?
