Outdoor Patio Lights To Dimmer - Electrical - DIY Chatroom Home Improvement Forum
Old 12-27-2012, 04:35 PM   #1
Rewards Points: 18
Outdoor Patio Lights to Dimmer
I recently purchased 3 sets of these and they hook end to end like christmas lights and have a normal 2 prong plug.
http://www.target.com/p/smith-hawken..._23&term=patio lights
I plan to use them outside on my patio and would like to wire them to a dimmer. My plan was to extend a current outlet to a new outlet and have a dimmer control that outlet. The issue with that though is it is not to code to control a normal receptacle with a dimmer. I then thought to just wire the lights directly to the dimmer (which extends off the outside outlet). Is this even to code since the lights do not have a ground?
mginster is offline   Reply With Quote
Old 12-27-2012, 04:41 PM   #2
dmxtothemax's Avatar
Rewards Points: 5,508
This would mean that the outlet has no ground !
Some places will allow ungrounded outlets,
Since your profile does not say were you are at,
cant say for sure.
You should check code requirements in your area !
dmxtothemax is offline   Reply With Quote
Dimming and Flickering lights in home Keisha34 Electrical 34 06-05-2012 02:22 PM
Caused a short at dimmer switch - now lights won't turn on HighVolume Electrical 4 10-18-2011 02:27 PM
4 way dimmer for led can lights edwardvdh Electrical 3 10-14-2011 03:34 PM
Dimmer switches brokenknees Electrical 9 11-29-2009 05:59 PM
How many 50 pot lights can I attach to a single dimmer? atm Electrical 1 04-16-2009 10:10 PM
