Outdoor Panel - Extra Wide Hole - Electrical - DIY Chatroom Home Improvement Forum
Old 10-06-2013, 11:52 PM   #1
Rewards Points: 248
outdoor panel - extra wide hole
How big a no-no is it to extend a hole in the back of an electric panel? It is an outdoor panel mounted on a piece of wood outside a house. I need to cut the hole a little wider to make something fit. The hole is in the back of the panel. That would mean cutting a little (1-2 inches) beyond the manufacturer knockout.
jackwashere is offline   Reply With Quote
Old 10-07-2013, 12:42 AM   #2
Oso954's Avatar
Rewards Points: 1,126
Maybe you should tell us what "something" is, before asking if it is OK.
Oso954 is online now   Reply With Quote
Old 10-07-2013, 04:32 AM   #3
Rewards Points: 248
I already did it. For a boneheaded reason that I am embarrassed to tell. I did not really need to do it but damage is done.
Should I get a welder from Harbor Freight and try to patch it back up before the inspector sees it or does it not matter?
Old 10-07-2013, 05:46 AM   #4
Electrical Contractor
kbsparky's Avatar
Welder?? Sounds extreme.
How about using a flat blank plate, fastened with a couple of TEK screws?
Less than $2
-KB
Old 10-07-2013, 12:45 PM   #5
Rewards Points: 330
in my opinion,if I was the inspector,and you welded the hole,i would make you tear it out and replace panel.beacause you can get KO seals to fix or as KB said.
oleguy74 is offline   Reply With Quote
How to repair a hole in cast Iron pipe? bofusmosby Plumbing 26 11-13-2011 09:35 AM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
Whats the deal with Hole Saws (price!!)? L4nce0 Tools 5 09-29-2010 09:10 AM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 10:28 AM
Fixing 11" Hole in Concrete Foundation robertr4836 Building & Construction 6 02-04-2008 08:08 AM
