Outdoor Outlets Don't Work - Electrical - DIY Chatroom Home Improvement Forum
Old 07-22-2011, 07:42 AM   #1
Outdoor outlets don't work
Hello!
I have two outlets outside (one in back and one in front) that do not work. The wires for each come from a single gfi located in my basement. When I tested the gfi it worked properly but when I tested the outdoor outlets it read open neutral. I opened the gfi and checked to make sure all of the wires were secure and everthing looked tight. For each connection (black, white, ground) there is one wire from the gfi crimped to two wires (one for each outlet).
The white seemed a little loss so I pulled off the old crimp and replaced it but now the outlets outside read open hot. The gfi still works but not the outlets after it. Any ideas? Should I call an electrician?
john620 is offline   Reply With Quote
Old 07-22-2011, 07:54 AM   #2
Master Electrician
Rewards Points: 3,678
Turn the power off. Remove GFCI from jbox. Note and or tag load and line wires connected to GFCI. Remove wires from GFCI. Temporarily connect black to black and white to white at GFCI jbox. Restore power and check downstream receps. If the dwnstrm receps are working, cut power, reinstall GFCI, turn power back on and recheck dwnstrm receps. If not working,cut power and replace GFCI.
brric is offline   Reply With Quote
Old 07-22-2011, 08:11 AM   #3
Thanks I will test this out tonight.
Old 07-22-2011, 08:29 AM   #4
Master Electrician
Check the neutral splices as well at the GFCI j box.
Old 07-22-2011, 08:45 AM   #5
I also wanted to ask about the splice. Once I figure out the issue and go to put it all back together, do i have to use a crimp or can i use a wire nut? I don't have the proper tool for the crimp but would be willing to pick it up if I must.
Old 07-22-2011, 08:49 AM   #6
I=E/R
a7ecorsair's Avatar
Nuts are fine...
a7ecorsair is offline   Reply With Quote
Old 07-25-2011, 03:08 PM   #7
Thanks for the help. Looks the GFI went bad. I replaced it and reconnected the crimped wires with wire nuts. Everything is working great...thanks again for the advise.
grounding the workpiece you're welding jarnold Electrical 43 01-03-2016 08:14 PM
Issues w/ Old Work Box mkrawitz Electrical 5 04-19-2010 12:53 PM
HVAC contractor ripoff! sekntonone HVAC 8 04-05-2008 08:15 AM
Need help with permit/city got a Stop Work Order. amdspitfire General DIY Discussions 39 02-07-2008 03:45 PM
Am I being overcharged for general construction work? baloney12 Building & Construction 2 07-11-2007 07:09 PM
