Outdoor Outlets - Change To GFCI's? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-29-2011, 08:08 PM   #1
Rewards Points: 36
Question
Outdoor outlets - change to GFCI's?
I've "blown" both outdoor outlets (front and rear of the house) plugging in power tools. Both are household 15amp outlets with waterproof covers. The GFI for the one in front is in the kitchen, and I can't find the one for the back of the house. (Our younger son moved back "for awhile" and that part of the house is a disaster zone.) would I gain anything by changing them to GFCI's so I could reset them right there rather than trooping back into the house?
Mike68847 is offline   Reply With Quote
Old 06-29-2011, 08:11 PM   #2
Learning by Doing
Leah Frances's Avatar
Yes.
But you'll still have to find where the mystery one is.....
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
The Following User Says Thank You to Leah Frances For This Useful Post:
Mike68847 (06-29-2011)
Old 06-29-2011, 08:13 PM   #3
Rewards Points: 36
Thanks!
Old 06-29-2011, 08:22 PM   #4
Licensed electrician
Rewards Points: 1,030
Depending on the locations of the others you may need to add additional GFIs to provide protection upstream of the exterior receptacles.
Exterior receptacles have been prohibited from sharing the small appliance circuits in the kitchen/dining rooms for many years.
Old 06-29-2011, 08:26 PM   #5
Rewards Points: 36
Thanks, Jim. The house is fairly new - 14 years old. Maybe it's just old enough not to require the outside GFCI's. Good point about how outdoor outlets should be. I'll check with some buddies for help on correcting this (they know what they're doing).
Old 06-29-2011, 10:04 PM   #6
rbj
Would you believe...NEC 1971 code outside... 1987kitchen.
rbj is offline   Reply With Quote
Old 06-29-2011, 10:13 PM   #7
2011-14= 1997. code changed in 1987. Just missed.
Old 06-30-2011, 06:47 AM   #8
Rewards Points: 36
Wow! Better get them changed. Would you guys recommend outside outlets be re-wired so they aren't "tied in" with inside devices?
Old 06-30-2011, 12:59 PM   #9
rbj
Changing any other outlets connected to the two small appliance circuits in the kitchen I would say absolutely. For a quick fix where the outside receptacles are connected to inside wall circuits, installing a GFCI outside in parallel with those general branch circuits would be one solution. The outdoor overload would trip the outside GFCI and not the inside overcurrent protection device.
Old 06-30-2011, 09:20 PM   #10
Rewards Points: 36
Thanks!
Tags
gfci switch/outlet
Wrenches needed to change blade in mitre saw? Evil Scotsman General DIY Discussions 10 04-01-2011 01:00 AM
How to I change the filter. kadisa Appliances 1 03-31-2011 08:57 PM
is UG conduit size change legal? krazni Electrical 1 07-13-2010 03:17 PM
Compact GFCI's?? humberguy Electrical 5 06-09-2010 09:38 AM
Changing potty. Do I need to change the flange out? tarheelblue Plumbing 9 09-05-2008 12:41 AM
