Outdoor Outlet With Hardi Siding - Electrical - DIY Chatroom Home Improvement Forum
Old 05-15-2013, 12:28 PM   #1
Outdoor outlet with hardi siding
I see that Hardie recommends using Sturdi Build mounting blocks, does anyone know the best way to attached the outlet box, should it be recessed into the sheathing so the face of the box is flush with the face of the block, or do they recommend mounting the box against the sheathing and have it extend out a bit from the face of the block?
vtboy51 is offline   Reply With Quote
Old 05-15-2013, 12:31 PM   #2
Licensed electrician
Rewards Points: 1,234
I don't know about the Hardiblocks, but the electrical box can be recessed no more than 1/4" in a non-combustible surface.
Hardi board plank siding over T1-11 bluefitness Building & Construction 3 12-19-2008 08:55 AM
MW Vinyl windows w/ JChannel + Hardi Board Siding - Proper Flashing? jboeckler Building & Construction 1 09-20-2008 03:55 PM
What do YOU think of this HARDI siding deal?? justdon Remodeling 3 09-16-2007 12:54 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
