Outdoor Outlet Doesn't Work; Not Fuse - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-16-2009, 09:21 PM   #16
Originally Posted by Atroxx View Post
You may have actually received a shock and not even have felt it, GFCI's can trip that quick.
I'm not so sure; for more current it trips faster so it seems you get more or less the same dose each time.
Trip times for GFIs: T in seconds = (20/I)^1.43, with I in mA. This is a design goal, they actually trip quicker.
So, I = 20/(T^0.7).
For T = 300 seconds, I = 0.4 mA.
For 20 mA, the let-go threshold, you could get one whole second.
Old 06-16-2009, 09:30 PM   #17
That's good to know, I am unfamiliar with the inner workings of a GFCI, all I really know is how they trip and that they're supposed to go off PDQ. So was I right at all, or would it be impossible to get hit on a GFCI circuit and not feel anything?
Atroxx is offline   Reply With Quote
Old 06-16-2009, 09:37 PM   #18
Depends on how many cocktails you have!
Old 06-16-2009, 09:41 PM   #19
That's good to know, I am unfamiliar with the inner workings of a GFCI 1,
So was I right at all, or would it be impossible to get hit on a GFCI circuit and not feel anything? 2
1
http://www.national.com/ds/LM/LM1851.pdf
2 Dunno'.
Back in the 70s they gave shocks to 150 pound dogs, probably looking for fibrillation or other bad things, so they could set a trip limit.
Maybe it's a selling point; every time you get a shock that you feel, the GFCI is reminding you that it saved your life for a mere $10 or so.
Old 06-17-2009, 04:00 PM   #20
DIY'r
ScottR's Avatar
Originally Posted by frgwtchr View Post
Turns out the circuit breaker is not tripped but the GFCI that the whole circuit runs off of did trip.
Check the boxes downstream of the good receptacle for moisture. I had a leaky box that was tripping a GFI regularly, but the moisture wasn't obvious due to the receptacle and a mess of wires blocking the view.
ScottR is offline   Reply With Quote
Old 08-01-2013, 10:26 PM   #21
I realize this thread is very old, BUT it helped me out VERY much in the present day. I didn't imagine something outside could be linked to something upstairs in the bathroom. Thanks much!!!
L22
blaisev22 is offline   Reply With Quote
Tags
electrical outlet box , gfci switch/outlet , outdoor wiring
Fuse Boxes For Showers Petrena Electrical 3 09-13-2008 01:36 AM
Problems with new fuse box for a dryer. needsomehelp Electrical 12 04-10-2008 11:20 PM
broken home fuse GPEACHL Electrical 3 02-05-2008 12:39 AM
