Outdoor Outlet Detailing W/ Thick Walls - Electrical - DIY Chatroom Home Improvement Forum
Old 08-02-2013, 07:22 PM   #1
Outdoor outlet detailing w/ thick walls
I am working on a project that will re-skin my house. In the end the exterior walls will be 2 3/4" thick from the outside of the stud to the outside of the siding (1/2" plywood, Tyvek, 1"XPS, 3/4" Rainscreen, 1/2" Siding) I plan on using Quickflash (http://www.quickflashproducts.com/pr...lectrical.html) for all wall penetrations. But I'm having a hard time visualizing how the details work on the outlet and 3/0 box.
So for example the max depth on the E-SGB-C is 1 3/8". The quick flashing goes at the tyvek layer, that still leaves 2 1/4" (2 3/4 - 1/2 plywood) to the outside of the siding. That means i'm left with a 1 1/8" gap. how do I deal with that?
Most of the outdoor covers I've seen only have a small lip on the back.
Any thoughts or input would be great! pic would be even better.
thanks
mmoses101-1 is offline   Reply With Quote
Old 08-02-2013, 08:19 PM   #2
Licensed electrician
Rewards Points: 1,010
Would one of these work?
http://www.aifittings.com/catalog/si...re-flange-box/
Old 08-02-2013, 10:18 PM   #3
Hadn't seen that product, but it has the same problem. It's only 1 1/4" deep thus it will not reach the the siding.
Old 08-02-2013, 11:12 PM   #4
Rewards Points: 506
Send a message via AIM to theatretch85
They make plastic boxes that have a metal bracket to attach to the stud (this is on new construction or where the stud is accessible) and there is a screw accessible from the front side of the box that adjusts the depth to meet the finished wall depth. I used these on the front of my garage and around the outside of my house when I had the siding re-done. Turn the screw so that the box is right where you need it, I think its a good 3" of movement it'll do.
theatretch85 is offline   Reply With Quote
Old 08-02-2013, 11:14 PM   #5
Rewards Points: 506
Oh I guess it only goes 1 3/4" here is a link to what I'm talking about: http://www.fleetfarm.com/detail/carl...FWJqMgodLF8AGg
Tags
electrical outlet , flashing detail , quickflash
Floating Basement Walls jonhayden Building & Construction 15 12-16-2013 09:53 PM
Spray Foam in Walls & Moisture Question leeave96 Insulation 4 11-12-2012 12:43 PM
Basement Walls - Which Paint?Drylok? HandyFrank Building & Construction 3 10-17-2010 01:07 PM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 06:59 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 09:17 AM
