Outdoor Outlet, Aluminum Siding - Electrical - DIY Chatroom Home Improvement Forum
Old 12-03-2010, 02:08 PM   #1
outdoor outlet, aluminum siding
whats the easiest way to install an outdoor outlet on a house with aluminium siding. doesn't seem that easy to remove and cut it without bending it up. can i just mount it flat against the house and drill a small hole for the wire? can i screw right through the siding into the sheathing and mount a box flat against the siding?
c00rdb is offline   Reply With Quote
Old 12-03-2010, 02:12 PM   #2
the Musigician
DangerMouse's Avatar
Sure can! But for outside, the box has to be the correct type, of course.
DM
Old 12-03-2010, 02:42 PM   #3
Rewards Points: 1,192
I cut the siding using a razor knife.
bobelectric is offline   Reply With Quote
Nothing Under Aluminum Siding dkel22 General DIY Discussions 9 09-30-2009 03:40 PM
Aluminum siding over existing old wood siding. timothevs Building & Construction 1 04-23-2009 04:13 PM
Adding a window - cutting through Aluminum Siding -how to repair siding to look good? DyerWolf Building & Construction 6 12-22-2008 04:02 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
