Outdoor Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 03-30-2014, 05:36 PM   #1
outdoor outlet
I have outdoor electrical outlet next to my tree. The outlet is being held up onto a pvc pipe with tie wraps. Also I have a freezer bag covering the outlet due to it being rusted and cracked..... can you give me a better way on hooking this outlet up?
What supplies would I need as well?
Homerlion is offline   Reply With Quote
Old 03-30-2014, 05:49 PM   #2
Master Electrician
Rewards Points: 3,920
Attachment 83291
Google Arlington Industries garden post.
brric is offline   Reply With Quote
The Following 3 Users Say Thank You to brric For This Useful Post:
gregzoll (03-30-2014), Jim Port (03-30-2014), k_buz (03-30-2014)
Old 03-30-2014, 05:59 PM   #3
Rewards Points: 14,026
If they messed all that up is the wiring at least rated UF?
Should have been A watertight box, watertight connectors, gray PVC run below ground, wires run at least 18" below ground.
In use cover over GFI outlet.
Old 03-30-2014, 06:04 PM   #4
Its the grey pvc run.
I just need a post and weather proof box, the plug us not GFCI
Old 03-30-2014, 06:09 PM   #5
Needs to be GFI.
Any box store has PVC water tight boxes and fittings.
Even a 4 X 4 will work as a post.
Posting a picture would sure help.
Homerlion (03-31-2014)
Old 03-30-2014, 06:16 PM   #6
Licensed electrician
Rewards Points: 1,788
The GFI needs to be weather resistant also.
Old 03-30-2014, 11:22 PM   #7
dmxtothemax's Avatar
Rewards Points: 5,512
If its rusted and cracked ! it needs to be replaced !
use a weather proof type in a proper enclosure.
install a gfci inside the house where the cables leave.
This way it protects all the cable to the outlet as well.
dmxtothemax is offline   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
oh'mike (03-31-2014)
Old 03-31-2014, 10:28 PM   #8
I would attach a picture but can not find the atta ch button.
Old 04-01-2014, 01:18 AM   #9
Oso954's Avatar
Rewards Points: 1,338
You need to hit the Brown "Post Reply" button below the last post, or if you are starting in the "Quick Reply" hit the "Go Advanced" button.
You will then have 2 rows of tool buttons. Hit the paper clip on the top row to attach a photo.
An alternative is to scroll down to the "Additional Options" and from the "Attach Files" Box, click "Manage Attachments".
You can hit the preview post button right next to the submit reply, to see the pic in your post.
Oso954 is offline   Reply With Quote
Old 04-02-2014, 12:47 PM   #10
Im utilizing my Samsung Galaxy S3 App. Cannot upload attachments from the app?
