-   -   Outdoor Outlet (http://www.diychatroom.com/f18/outdoor-outlet-136503/)
seansy59 03-09-2012 02:31 PM
Outdoor Outlet
14 Attachment(s)
I need to install an outdoor outlet in my backyard. The only outlet I have is in the front which is useless except at Christmas.
Under my house in the barely accesable crawlspace, runs a 15a line 14ga from the panel and feeds a now destroyed (head kept hitting it) light that is capped off in the junction box, and then runs over into the kitchen to feed a non-used gas stove outlet (converted over to electric range and had a 240v put in for it).
This light junction box is about 10ft from where I need to install an outlet on the outside of the house.
Questions:
1. Can I use this line? Nothing else runs off of it. I am going to cap off the old gas stove outlet because the outlet is inaccesable for use and is just filled with dirt/cooking grease. I have no need for it.
2. My plan is to run 14/2 out to the exterior, and put a 2 gang weatherproof box with the 14/2 clamped on coming in through the back, 15a GFCI outlet and on the load side of that another outlet, and a weatherproof in use cover. The 2 gang box will be siliconed and sealed or caulked etc. Is this correct?
The outlet will be used for power tools, work lights, and a fountain at times. Plus anything else. So I need a dedicated 15a, but have no more spaces in the panel to add a new breaker.
jbfan 03-09-2012 02:37 PM
Sounds good.
Jim Port 03-09-2012 02:38 PM
I don't see any issues as long as the old circuit is grounded.
The receptacles will need to be marked WR for weather resistant and TR for tamper resistant along with being GFI protected.
seansy59 03-09-2012 04:50 PM
14 Attachment(s)
Originally Posted by jbfan (Post 874194)
Sounds good.
Excellent!
Yup. I got those at HD before. The GFCI was the only one marked TR and WR. The basic one (Connected to load side of GFCI) was only TR. Is this a problem?
