Outdoor Mercury Vapor Lamp - Starting To Fail - Electrical - DIY Chatroom Home Improvement Forum
Old 01-14-2013, 05:03 PM   #1
outdoor Mercury Vapor lamp - starting to fail
Hi. We have an old (1970's-ish) outdoor lamp, automatic on/off. I think it's mercury vapor - the label says: USE ONLY MV-175 WATTS, TYPE H39 LAMP, 120V 60Hz AC Max 4.0A ...
It's been working fine for 40 or 50 years, but lately it sometimes fails to turn on, or turns on hours later than is should.
Any ideas why it would fail only intermittently?
cookieJones is offline   Reply With Quote
Old 01-14-2013, 06:05 PM   #2
Oso954's Avatar
Rewards Points: 772
First thing to try, would be to replace the daylight sensor.
Oso954 is online now   Reply With Quote
Old 01-14-2013, 06:18 PM   #3
Thanks Oso954 - Is it fairly simple - do they screw on/off or should I get an electrician? I know enough to turn the breaker off first, but that's about it.
Old 01-14-2013, 06:26 PM   #4
Rewards Points: 13,300
1/2 turn and lift it off.
Old 01-14-2013, 07:16 PM   #5
Excellent - thank you!
Old 01-14-2013, 08:16 PM   #6
Rewards Points: 528
Agree, thats what it was with mine also. I replaced mine-easy twist lock for 8 or 10 bucks .Day/night sensor.
hidden1 is offline   Reply With Quote
Old 01-14-2013, 09:22 PM   #7
Missouri Bound's Avatar
How long as the current lamp been in the fixture? MV's do last forever, but they get dimmer and dimmer....If it's been a while, you may want to change the lamp also.
Do you want it your way or the right way?
Old 01-15-2013, 01:16 AM   #8
" Euro " electrician
frenchelectrican's Avatar
They do last very long time however you still can get MV lamps but not the ballast they are no longer legit due the engery pact.
To OP ., If you want to keep simauir luminaire there is a metal halide verison it should have about the same light level as old school MV but only use about half of the power.
100 W MH is about the same as old 175 watter MV are and count the ballast loss that will add up fast so with MH it will actually about 120 watts or so depending on normal or high power facter ballast while common MV useally run about 225 to 250 watts.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
NJMarine (01-15-2013)
Air conditioner not starting - Help needed. pipster HVAC 18 09-26-2011 04:39 PM
Old Water Heaters - replace or wait to fail? AB1337 Plumbing 15 09-03-2011 07:57 PM
how to build a single phase induction motor sashman Electrical 3 03-31-2011 08:18 AM
Help! -- what is causing these shingles to fail? imaginator Roofing/Siding 1 09-18-2010 07:29 PM
Timecutter 16:42z trouble starting and now stopped starting jackdoldno7 Landscaping & Lawn Care 0 09-10-2010 12:43 PM
