Outdoor Load Center Indoors..... - Electrical - DIY Chatroom Home Improvement Forum
Old 01-31-2011, 10:02 PM   #1
outdoor load center indoors.....
Can a outdoor load center be used indoors? I don't see why not.... but thought I would ask the pros.....
I made the mistake of mounting my subpanel for the garage (attached) 2 feet outside. so this makes all the wiring a nightmare because I would have to j box everything, or conduit everything.... So I am thinking about relocating it to the interior of the garage, and then Romex will be fine....
Thoughts?
wackerjr is offline   Reply With Quote
Old 01-31-2011, 10:14 PM   #2
Electrical Supplier
Rewards Points: 150
I dont see why not......Its just a NEMA 3R enclosure....
Unless someone can recite a section of the code that does not allow 3R boxes inside.
I think the only problem you will run into is that Enclosure cant be mounted between studs, you will have to surface mount it and come in from the back of the box.....
If I remember correctly outdoor boxes do not have pre drilled KOs, you have to make them.
"Do it right the first time and avoid duplication of effort"
Your AHJ/Inspectors ALWAYS have the final say on ANY electrical code issue.
If in doubt, contact a licensed, experienced, reputable electrician to perform the work.
LyonsElecSupply is offline   Reply With Quote
Old 01-31-2011, 10:37 PM   #3
good point on the entry... but mine has a bunch of knock outs on the bottom.... and from the sounds of it I can mount it either direction....
Siemens W0816ML1125CU is my panel
http://cmsapps.sea.siemens.com/contr...x_01/01_09.pdf
Old 01-31-2011, 10:40 PM   #4
Electrical Supplier
Rewards Points: 150
I dont think the door will open if you flush mount it between studs.....It will fit, but you cant open it......most 3R enclosures require the door to be unlatched, then lifted and opened......I dont know if you can just get a flush cover that will fit it.....most have a dead front that is the entire box size and screwed into place.
I think you will have to surface mount it, and like I said, you cant use the bottom knockouts, your romex will be exposed. You will have to enter from the back of the enclosure.
Center bearing vs. Clear Span floors -- Span Tables WaldenL Building & Construction 2 02-24-2015 07:50 AM
Jacking up house, full length joists raised beam off of center colums. Suggestions? slowjo Building & Construction 9 09-16-2014 07:56 AM
Ductwork Around Center Beam Build HVAC 6 06-16-2009 11:56 AM
Moved ceiling light in bedroom to center, now trips breaker blthomas Electrical 18 01-24-2008 05:29 PM
Drilling into Center Beam leted_82 Building & Construction 2 03-06-2007 09:52 PM
