Outdoor Lights On Kitchen Light Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 08-28-2009, 11:05 AM   #1
WaldenL's Avatar
Rewards Points: 268
Outdoor lights on Kitchen Light Circuit
I know I can't pull off the kitchen plug circuits for outdoor lights (or just about anything else) but are there any restrictions to pulling off a circuit that feeds the kitchen lights? "Outdoor lights" means a spot light mounted on the house, and a couple of under-eve cans.
The current setup (if I've figured it out right ) has the outdoor lights pulled off the kitchen plug circuit, and I want to fix that. Not only because it's "wrong" but because the splice was done inside a box that didn't have a cover, and was buried in the ceiling of the kitchen (don't look at me). Since I've got the ceiling open anyway now I want to fix that part too.
WaldenL is offline   Reply With Quote
Old 08-28-2009, 11:28 AM   #2
Licensed electrician
Rewards Points: 1,864
Outdoor lighting can share the circuit with the kitchen lighting providing there is enough reserve capacity in the circuit.
Old 08-28-2009, 11:40 AM   #3
WaldenL's Avatar
Rewards Points: 268
Define "reserve capacity"... do you simply mean that the circuit isn't yet at it's max. It's a 15A circuit, so that would be 15A, right? I'm no where near that. New run for kitchen lights, using CFLs and track and ceiling fan. Or is there a special "reserve capacity" for kitchens?
Old 08-28-2009, 11:52 AM   #4
I meant that you would have the ability to run everything on the circuit without it tripping due to overload.
Old 08-28-2009, 12:02 PM   #5
With switching to CFL's I have a lot of spare capacity on my lighting circuits
One circuit I will not load up is the one the smokes are on
I try to never connect enough fixtures to a circuit that, if they were all on, would trip the circuit
I had thought that was required by code, but was recently told it is not required by code (in a residential setting?)
Possibly required in a commercial setting....??
Old 08-28-2009, 01:16 PM   #6
WaldenL's Avatar
Rewards Points: 268
Great. Then I'm all set. One more wiring issue fixed. I swear, this house was wired by someone that got paid a bonus for each screwed up solution they could implement!
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Adding 15 amp light and switch on a 20 amp circuit Jzack26 Electrical 1 08-02-2009 04:02 PM
15A rated light switches/dimmers OK on 20A circuit? red86yota Electrical 3 03-01-2009 11:43 AM
Adding a light to an existing 3 way circuit rlferdig Electrical 4 09-16-2008 02:47 PM
