-   -   Outdoor lights flickered and died? (http://www.diychatroom.com/f18/outdoor-lights-flickered-died-175229/)
Bennylava 03-22-2013 02:52 PM
Hi all. I just installed a nice new pair of outdoor lights outside my front door. I got some fancy pants looking ones from lowes. I took the old crusty ones down, and installed these new ones. They worked for about 3 days. The first next day, they worked fine. The second day, they flickered for a few seconds, but then seemed to reluctantly work.
The third day, all they would do is flicker. The fourth day they wouldn't come on at all, and haven't came on since. Is this just a bad connection? I'm pretty good at soldering and I could solder all the wire connections if I need to.
joecaption 03-22-2013 03:00 PM
Do no solder them, just go back and check for a bad connection.
dmxtothemax 03-22-2013 05:18 PM
Are they PIR controled lights ?
Bennylava 03-23-2013 07:43 AM
Not sure what PIR means. They do have a sensor though. They're set to come on whenever they detect movement, but only at night. However, they have several settings including always on, and no setting works.
JulieMor 03-23-2013 08:21 AM
A competent electrician can solve your problems. This is one of the many reasons why manufacturers tell the buyers of their electrical products to hire a qualified electrician to do the installation.
Bennylava 03-23-2013 10:24 AM
There is no reason a DIY'er couldn't easily do this task. Its three wires. That's it. This is the "DIY" forum, is it not? I just have a bad connection somewhere. That's why I was asking if I should solder that way I could rule out bad connections on my part.
MCB 03-23-2013 12:46 PM
And you are saving energy for the good of the country with CFLs in them? If this is the case, the energy saving bulbs may have been fried by the "sensor". Check your connections and replace the bulbs with regular incand to test.
dmxtothemax 03-24-2013 12:28 AM
You could have a go at resoldering the circuit board !
provided you can solder well !
But also check for simple things like
loose wires, loose contacts in lamp holder.
You will dissconnect it first wont you ?
"P" assive "I"nfa red "S"ensor.
