Outdoor Lights Cable Cut - Electrical - DIY Chatroom Home Improvement Forum
Old 10-29-2007, 10:33 AM   #1
Unhappy
outdoor lights cable cut
I accidentally cut the cable of my Christmas solar lights. I then stripped the four cable ends on each side and rewired them but they don't work. Is there a particular order to wire the four cables?
ASantosdiaz is offline   Reply With Quote
Old 10-31-2007, 12:33 PM   #2
Contractor in PA
You probably blew a diode or another electronic component
michaelpwalton1 is offline   Reply With Quote
Old 11-01-2007, 02:24 PM   #3
Rewards Points: 78
Are the cables color coded? Did you connect the right wires together?
If they are not color coded, look at both ends where it was cut. You may be able to see the order of the wires that go together. Like a flat cable, you can see the ribs of the outer covering and maybe you can figure out which wire goes with the other. 4 wires for sure has to be connected identicle.
As said above, If you are sure the wires are connected right, it might be the solar panel or related. I hope not.
Do you have a wiring diagram (manual) for the system? Thats where I would start
In-Floor Heating Cable Trouble... sootybuttercup Electrical 24 12-18-2014 09:01 PM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 03:54 PM
upgrading service cable Clutchcargo Electrical 1 06-22-2007 11:04 AM
CABLE for TV in basement DIY4EVER Electrical 5 06-19-2007 07:01 PM
Running CATV cable tima2381 Remodeling 4 03-27-2007 11:17 AM
