Outdoor Lighting Hookup Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 08-30-2008, 06:11 PM   #1
Rewards Points: 654
I am installing outdoor low voltage lighting at my home. I went to plug the set in and didn't even think about the type of plug that it had. I have the standard single gang outlet with an weather proof outlet cover on it. The type of plug that this transformer has is too long to fit within the outlet cover and allow it to be closed. Does anyone know of another type of weather proof cover that will work for for this situation? Following is a link that will show a picture of the transformer that I am referring to. Thanks for your help!
FCGG-2A6LA
kennykenny is offline   Reply With Quote
Old 08-30-2008, 06:38 PM   #2
the Musigician
DangerMouse's Avatar
Smile
this maybe?
hi kenny, thought you were dead... =o)
i used this to do my outdoor "oliver douglas" phone on the pole trick. transformer fit fine in top outlet.
DM
Old 08-31-2008, 06:03 PM   #3
Rewards Points: 654
The transformer that I am using is 6 in from top to bottom. The cover that I have on my outlet is similar to what you are showing me but is just a single gang cover. The transformer will not fit within the box that you are showing me and allow me to close the top. Any other suggestions. Thanks!
Old 08-31-2008, 06:38 PM   #4
the Musigician
welp, for the cordless phone i put on the pole, i built a small wooden box with a hunk of shingle on top and a rubber sheet 'door'.
maybe something like that? unless it needs to pass a code, in which case, call your local inspectors.
DM
(you'd think the manufacturers would have forseen this and made the darn thing smaller, you know? sheesh!)
Old 08-31-2008, 06:42 PM   #5
Rewards Points: 654
My thoughts precisely........Thanks!
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
GMP100-3 Problem hansim4 HVAC 2 12-13-2007 04:55 PM
Phone Jack Hookup Problem kennykenny Electrical 18 12-07-2007 04:48 PM
1994 camry rear suspension/tires problem marks5894 Automotive Repairs 2 11-05-2007 06:12 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
