Old 10-08-2012, 08:00 PM   #1
gkaro's Avatar
Outdoor light on siding
Hi all.
Just built an extension and it time to install the outdoor lights on the wood siding. I have the wires coming through holes to the outside. Where I am having difficulty is if I install an octagonal box on the siding, the light fixture will not cover the box and it will show from the sides.
Should the siding be cut and boxes be installed flush mounted with the outside surface???
I was under the impression that outdoor boxes were always surface mounted...
gkaro is offline   Reply With Quote
Old 10-08-2012, 11:44 PM   #2
There almost never surface mounted.
A lot depends on what's under the siding. Some old houses just attached the siding directly to the studs with no sheathing.
A simple way to get this done would be by using one of these.
http://www.midamericabuilding.com/co...70&parentid=-1
Old 10-08-2012, 11:58 PM   #3
Resi EC
Originally Posted by gkaro View Post
Hi all.
This is the best solution,(OP in red).
The big box stores have round re-model cut-in boxes that work well for this type of installation.
No, not all outdoor boxes are surface mounted.
Yes, there are weather resistant surface mount light boxes, they don't look very well with regular fixtures. Flood lights are all I try to mount to these.
Gac66610 is offline   Reply With Quote
Old 10-09-2012, 07:15 AM   #4
Arlington Industries has a good variety of cut-in mounting blocks and retrofit mounting blocks.
http://www.aifittings.com/catalog/si...unting-blocks/
The mounting block below is for 1/2 lap siding and the kit includes a built-in electrical box.
Outdoor light on siding-8141-2.jpg   Outdoor light on siding-new-bitmap-image.jpg
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
joecaption (10-09-2012)
Old 10-09-2012, 07:32 AM   #5
Resi EC
Well, that looks easy enough, I could probably handle installing one of those.
Old 10-09-2012, 07:43 AM   #6
Electrical Contractor
They are easy, but it comes in about 3, maybe 4 styles, depending on the type of siding.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 10-09-2012, 07:47 AM   #7
Resi EC
I do mainly new construction, so using a hole saw with ceiling nail-on boxes is the easiest for me.
Re-mod can be a whole other world.
Old 10-09-2012, 09:02 AM   #8
gkaro's Avatar
Ok thanks guys. I've got house wrap over the ply, then 1x2 strapping for air/ water space behind the siding.
If I use a reg box flush mounted as you describe...where does the sealing take place? How do I ensure that I don't have water issues?
Old 10-09-2012, 09:11 AM   #9
Sealing around where the wire comes through the wall is all you really need.
If you try sealing around the flush mount you may trap water inside of it.
Old 10-09-2012, 09:41 AM   #10
Can you provide a picture of your siding?
Old 10-09-2012, 10:57 AM   #11
gkaro's Avatar
Old 10-09-2012, 10:58 AM   #12
gkaro's Avatar
It's an eng wood siding from kwp products
Old 10-09-2012, 11:16 AM   #13
gkaro's Avatar
Hey joecaption
Thanks... A bit confused.
I cut a hole in the siding to fit the box... Mount the box inside flush with the front of the siding and only seal the hole where the wires come through??? What if water gets into the electrical box itself???
Or am I not understanding something???
Old 10-09-2012, 01:27 PM   #14
Resi EC
Hey joecaption
After you mount the fixture, seal around the top and sides of it, leave the bottom unsealed.
How to Nail New Siding Under Existing Siding Shuriko Building & Construction 25 05-21-2012 09:33 PM
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 11:07 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
