Outdoor Landscape Lights...is This Possible? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-22-2012, 06:26 PM   #1
outdoor landscape lights...is this possible?
I would like to run @ 25 outdoor pagoda lights (15-25W bulb max) down a 500' driveway. I will be using 1/2" plastic conduit throughout for shovel protection...
I would also like to include 3 or 4 spotlights (50W max) for tree lighting.
Question:
1) What UFB gauge wire and what circuit would you recommend?
2) Would there be any juice left for receptacle? (driveway radio alert system)
Thank you.
ohboybills is offline   Reply With Quote
Old 03-22-2012, 06:32 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Would this be a low voltage system or 120V?
Old 03-22-2012, 06:34 PM   #3
120 volts...thanks
Old 03-22-2012, 06:39 PM   #4
k_buz's Avatar
500' is quite the run, I'd suggest running 10-2 UF and putting the run on a 20A circuit.
Running UF in any 1/2" conduit would be a very tough pull over any sort of distance. I am going to suggest that you run a 1" PVC if you are dead set on installing a conduit.
That would include that added GFCI.
Old 03-23-2012, 08:49 AM   #5
Thanks K_Buz!
I was hoping not to have to borrow against the house to buy that much 10-2 gauge!
Bill
Old 03-23-2012, 09:01 AM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
I would not run uf cable.
I would use thwn and the conduit.
jbfan is online now   Reply With Quote
Old 03-23-2012, 09:05 AM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
Use THWN wire in conduit. You will kill yourself trying to pull in UF.
Consider solar lights.
Coastal South Carolina
Old 03-23-2012, 11:18 AM   #8
Thanks guys! This is a great forum and I appreciate your time and input.
I was going to "monkey" pull the wire in 10' sections, prior to burying.
Also, I had 500' of 14-3 UF wire laying around and was hoping to use it, since the pagoda lights were going very low watt.
Damn long driveway...
Still trying to get used to the "ice-cold" solar look
Old 03-23-2012, 12:45 PM   #9
A "Handy Husband"
rjniles's Avatar
Use the 14/3 to establish 2 separate 120 v, 15 amp circuits. Your load is under 7 amps. At 500 feet 3.5 amps (splitting the load between the 2 circuits) on #14 wire has a voltage drop of a little under 10%. Should be OK for lights
Old 03-23-2012, 06:56 PM   #10
Excellent. I like that approach; thanks guys
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 09:52 AM
Need info on replacing 8 recessed lights in bathroom OhmZoned Electrical 1 11-07-2011 01:35 PM
Use factory fog light switch for aftermarket lights? downunder Automotive Repairs 6 07-10-2010 12:45 PM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 09:37 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 08:23 PM
