Outdoor Lamp Post No Power - New Homeowner - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-05-2012, 03:05 PM   #16
Rewards Points: 285
Originally Posted by sgip2000 View Post
The cut wire you found could be for cable TV.
That's my hope!
marcus118 is offline   Reply With Quote
Old 12-05-2012, 04:29 PM   #17
Electrical Contractor
jbfan's Avatar
Rewards Points: 542
Thats the way I would have done, but sometimes you scratch your head and wonder what was the other guy thinking.
Look in thw crawl space and see if you can foloow the wire from the switch.
Got a picture of the cut wire?
Does your cable/phone come into the house orver head?
jbfan is online now   Reply With Quote
Old 12-05-2012, 05:09 PM   #18
seansy59's Avatar
Rewards Points: 258
It could be an irrigation control valve wire. Do you have a sprinkler system?
Sometimes valves are placed in remote areas, and they run a wire all the way to them. Really silly I think to run things to distant locations, but, that's how some do it.
seansy59 is offline   Reply With Quote
Old 12-05-2012, 07:03 PM   #19
Rewards Points: 285
Ah you just sparked a thought! The yard is wired with a dog fence. Perhaps that is the stray wire.
Old 12-05-2012, 07:07 PM   #20
jbfan's Avatar
Rewards Points: 542
If it is cut, then it was wired for a dog fence!
Old 12-06-2012, 12:42 PM   #21
Rewards Points: 285
went outside and found a spot in the wire where i could read the labeling. "paige 14awg containment tracer wire"
after a quick google search, here it is: http://www.petstuffwarehouse.com/dog...undarykit.aspx
so it's the dog fence wire.
now i can focus on why the lamp post isnt getting power!
Old 12-06-2012, 02:21 PM   #22
TTW
TTW's Avatar
Take the scissors away from the dog!
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 12-06-2012, 03:02 PM   #23
Rewards Points: 115
What kind of tester are you using? Does it just lite up? Do you know if you have 120 volts present? Is anything else in the house not working? What do the other two switches do?
pokey is offline   Reply With Quote
Old 12-07-2012, 12:20 AM   #24
dmxtothemax's Avatar
Rewards Points: 5,494
Start by pulling the breaker !
Check both sides of switch to be sure its dead !
Dig a hole behind the pole and try to find the wires.
Which direction do they go ?
If they go back along the path,
then dig another hole beside the path 1/2 way along,
Find cable, if found, dig again near the top of the path,
You get the drift ?
Happy hunting !
dmxtothemax is online now   Reply With Quote
Old 12-08-2012, 01:41 PM   #25
Rewards Points: 285
Was finally able to get outside today and take apart the lamp post. I got down to the ground wires coming into the pole to test them for power. Doesn't look like they're getting anything. Here's a pic:
So I'm concluding the problem is underground :-(
Anyone have any final thoughts before I start digging????
Old 12-08-2012, 04:55 PM   #26
TTW
TTW's Avatar
Can you back the camera up a bit so we can see both wires? I only see the nm cable, and would like to confirm that the underground wire is rated for underground use (UF cable).
Old 12-09-2012, 07:05 AM   #27
Resi EC
Rewards Points: 252
I drew a little diagram to show what I'm talking about with that random cut wire on the ground by the side of the house.
I'm no electrician but wouldn't the wire from the switch be running underground along the sidewalk out to the lamp post?
I'm hoping that random cut wire has nothing to do with the lamp post
Try looking behind the bushes on the front of the house, there may be a junction box that leads to the yard light
Gac66610 is offline   Reply With Quote
Old 12-10-2012, 09:31 AM   #28
Rewards Points: 285
One thing I probably should have mentioned is that when I moved into the house, the actual light on top of the post was shattered and had no light bulb (guessing their kids threw a baseball at it). So it was exposed to rain for quite some time I would imagine.
Could this be why it's not working?
Old 12-20-2012, 07:27 PM   #29
Rewards Points: 115
lamp post
did you ever figure out the problem?
Old 12-21-2012, 07:58 AM   #30
Rewards Points: 285
Nope haven't had a chance to get back out there. Tomorrow I'm going to dig down near the foundation to find where the wire goes in the house. Perhaps there is a junction box outside the house?
Following up on my previous question, I suspect the line shorted out from water getting in the old broken lamp top. If so, what/where exactly would I need to make a repair?
Compressor terminal post wiring connector came apart - remnant still sticking to post justplumducky HVAC 11 07-06-2011 08:04 PM
