Outdoor Hot Tub Wiring - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-10-2009, 08:34 PM   #16
Originally Posted by Scuba_Dave View Post
Not on a hot tub
Always an insulated ground
I can't believe a supply house doesn't have THWN
Is it an electrical supply place?
Contractor supply - you would think they have it
Not a new employee was it
I had to run to the Homey Depot to pick a few things up and I wandered over to their wire rack and found that they have 6ga stranded THHN/THWN-2. I presume the guy I talked to a the supply house (yes, it was an electrical supply house) must have been new, or nobody ever asked for it as THWN. By far the simplest, cheapest, fastest, and safest way will be to get the individuals and conduit them. Unless the inspector has something different to say tomorrow, I'll plan on that.
Appreciate all the input folks.
SteveA is offline   Reply With Quote
Old 06-10-2009, 08:45 PM   #17
He shouldn't have anything different to say. Stranded in conduit is code. Does your tub require 240V or 120/240V?
jerryh3 is offline   Reply With Quote
Old 06-10-2009, 08:58 PM   #18
Electrical requirements are 240V 50Amp GFCI with 6 AWG. I'll call (probably another) supply house tomorrow and look for the right wires.
Old 06-10-2009, 09:03 PM   #19
And, you do know you only need #10 for the ground.
Old 06-11-2009, 10:34 AM   #20
I just spoke with the local inspector and he has no problem with using UF w/Ground for the entire project. He said as long as the box is properly grounded, that is more than adequate. As long as he'll accept it, I'll probably go that route for the time being as I've got easy access to affordable 6/3 UF. Everything is accessible though so that in the future I may replace the wire in the short span (5ft) of conduit going from the house to the spa.
When it comes down to it, the inspector needs to be the one satisfied I guess.
Old 06-11-2009, 10:41 AM   #21
The fact that the local Inspector doesn't know the proper code does not make this meet code or a safe installation.
Old 06-11-2009, 04:05 PM   #22
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Originally Posted by scuba_dave View Post
the fact that the local inspector doesn't know the proper code does not make this meet code or a safe installation.
+1 !!!!!!!
Old 06-11-2009, 05:25 PM   #23
Licensed Pro
Inspectors have been known to be wrong (GASP!), you know.
Old 06-11-2009, 05:44 PM   #24
Licensed electrician
Rewards Points: 1,876
I would not install a code violation knowingly whether the inspector said it was ok or not.
Another thing, the subject of bonding the rebar or mesh in the concrete pad needs to bond to the lug with a #8.
Old 06-11-2009, 11:46 PM   #25
liscenced electrician
Rewards Points: 538
You guys are ridiculous sometimes someone please give me the reasoning that an un insulated ground inside an insulted cable inside a conduit is so unsafe
jimmy21 is offline   Reply With Quote
Old 06-12-2009, 12:33 AM   #26
" Euro " electrician
frenchelectrican's Avatar
I hope that inspector is joking on that matter. C'est dingue!!(*)
There is no way in heck I will install for hot tub . spa or pool like that arrangement.
The code is very well written in there and you can not ingore it.
Merci,Marc
(* it is nuts )
Old 06-12-2009, 12:42 AM   #27
The pool , spa , hot tub have very specfic code the issue is voltage graduent that is been written in the NEC code book for the last 20 some years
The other thing that I know alot of peoples try to do this route by running the UF cable in the conduit 90% of the time is a major no-no there however once it get out of the underground you can run the UF without conduit or with conduit only for protection { this part I am NOT crazy with it at all and I don't go this route at all }
There are few very well respected members they will chime in with few good choice words that they will get to the point no bullcrap around this one.
Merci,Marc
Old 06-12-2009, 01:30 AM   #28
Rewards Points: 538
Does this mean you couldn't use grc?
Old 06-12-2009, 05:20 AM   #29
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Sure you can use rigid, as long as you have an insulated ground in it.
wirenut1110 is offline   Reply With Quote
Old 06-12-2009, 12:59 PM   #30
Rewards Points: 538
But if you ground both sides of the pipe ět is now in parallel with your ground and 100% bare
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 08:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
