Outdoor GFI Problems - Electrical - DIY Chatroom Home Improvement Forum
Old 12-27-2006, 11:09 AM   #1
Question
New User here and I have a problem with an outdoor GFI outlet -
House is only 18 months old and the outdoor outlet worked fine until recently. Had the Christmas lights plugged in to this outlet and they were working great but, one day it rained and I noticed the next evening the lights, on a timer, did not come on. I tested and reset the outlet, and it still did not work. Checked the panel and the breaker hadn't tripped so, I assumed moisture had gotten into the outlet and replaced it. Now, however, when I plug anything in to the new GFI, it trips. What am I missing that I need to do?
kr404 is offline   Reply With Quote
Old 12-27-2006, 04:45 PM   #2
Check to be sure that when you put the new gfi in, you have the Line, and Load wired correctly.
jwhite is offline   Reply With Quote
Old 12-30-2006, 01:31 AM   #3
As jwhite said....... Also, check and make sure:
- your bare copper ground has not 'folded' and is touching your neutral (white) terminal screw.
- you said it trips when 'anything' is plugged into it. Do you mean the same light string that tripped it before, or have you tried plugging something else into it to test it. Its quite possible that your lites or cord have a short, either by damage or water saturation.
-Greg
smokumchevy is offline   Reply With Quote
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 01:51 PM
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 06:29 AM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 08:43 AM
